Tip & How-To about Computers & Internet
How to clean a keyboard
Shut down the computer and detach the keyboard connector before any cleaning procedure. Do not remove or connect a keyboard while the computer is running. Doing so may damage the machine, especially a non-USB based keyboard. Detaching the keyboard while the computer is running is safe when the keyboard is connected to the computer via usb.
For a quick cleaning, turn the keyboard upside down and use a can of compressed air to blow out any foreign matter. Be sure to do this in a location where falling debris can be cleaned up easily. Turn the keyboard upside down and tap on it a few times. You should see a bit of dirt fall out. Change the angle and tap harder to make most of it get out
3Clean the sides of the keys with a cotton swab dipped in isopropyl alcohol.Clean the individual keys and place them back in the keyboard.
dont remember to rate this post,than you!
Computers & Internet Logo
My laptop shuts down in 5-10 mins.
Instructions
Purchase a new fan for the Sony Vaio model you have by checking the owner's manual of your computer or consult the Sony website for the correct part number.
Remove the power cord from your computer and then remove the battery. Unlock the battery and slide it from the bottom of the laptop. Allow it to sit for 5-10 minutes after removing the battery.
Turn the computer with the left side facing toward you and locate the only screw found on the left side and remove it. Remove the panel by sliding it toward you and set it aside.
Slide the panel covering the power buttons to the left and detach the ribbon cable connecting it to the motherboard and then remove the panel gently.
5
Remove the keyboard by unscrewing the small screw directly above the keyboard. Once the screw is removed, gently lift the keyboard and detach the small cord connecting it to the motherboard. Set the keyboard aside.
6
Remove the plate under the keyboard by unscrewing the three screws and lift the plate out.
7
Disconnect the cooler fan from the motherboard by pressing the connectors in and removing them from the sockets. Once the connections have been removed, lift the cooling fan up out of the computer.
8
Replace the old fan with the new one you purchased and attach the two connectors. Reinstall the metal plate back on top of the fan and attach the screws.
Jan 10, 2013 | Dell Inspiron 1545 Notebook
how to remove keyboad on a laptop hp g61
The procedure is straignforward. For step by step intructions download the service manual from
http://h10032.www1.hp.com/ctg/Manual/c01868653.pdf
Please rate this solution. Let me know if you have any problems or questions. Thanks.
Jun 09, 2011 | Computers & Internet
How to replace keyboard for HP Pavilion DV2700?
Below is the link to the service manual and below that are the steps to the procedure. If want, open the manual and follow along with the procedures below, they are linked and cooincide with one another. The manual is free to copy, print and use.
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery (see Battery on page 56).
Remove the keyboard:
1. Turn the computer upside down, with the front toward you.
2. Remove the three Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
3. Turn the computer display-side up, with the front toward you.
4. Open the computer as far as possible.
5. Lift the rear edge of the keyboard (1) until it rests at an angle.
6. Release the keyboard (2) by sliding it back to disengage the tabs on the front edge of the keyboard
from the top cover.
76 Chapter 4 Removal and replacement procedures
7. Lift the rear edge of the keyboard (3) and swing it forward until it rests on the palm rest.
8. Release the zero insertion force (ZIF) connector (1) to which the keyboard cable is attached and
disconnect the keyboard cable (2) from the system board.
9. Remove the keyboard.
Reverse this procedure to install the keyboard.
Nov 05, 2009 | Computers & Internet
power plug on laptop not working
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system1.gif.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
Feb 05, 2008 | AMD BALANCE A535 NOTEBOOK MOTHERBOARD WITH...
Altec Lansing speakers in laptop
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
toward you.
Close the computer.
toward you.
from the LED board.
toward you.
http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Jan 14, 2008 | HP Pavilion dv6000z Notebook
230 people viewed this tip
David Payne
David Payne
