Tip & How-To about Audio Players & Recorders
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
what is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
How I connect a Karaoke and get the 5 speakers sound ? The karaoke have 1 rca out for video, and 2 rca out for sound. Thanks
The home theater system will various surround mode like Prologic / All channel stereo / matrix etc.These surround modes are to make all the 5 channels to work in various ways from a two channel input like your Karaoke mic. Choose one setting to your liking
Apr 08, 2011 | LG LHT854 Theater System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
306 people viewed this tip
 Grubhead
Grubhead
