Tip & How-To about Coffee Makers & Espresso Machines
Fixing traditional home espresso coffee machine, Gaggia, Saeco, La pavoni, Rancilio, Francis
Fixing traditional home espresso coffee machine, Gaggia, Saeco, La pavoni, Rancilio, Francis Francis
FrancisFrancis X1 , X5, Gaggia Baby, Nuova Simonelli Oscar , Ascaso Dream , Gaggia Classic , Rancilio Silvia Rancilio Silvia
The in formation on this page is for use of technicians and experienced persons. All others do so at their own risk.
Traditional Home Espresso Machines Have the Following Parts:
1. A brass or aluminum boiler (16 to 40 oz. capacity).
2. A boiler outlet valve to help increase the pressure of water, before it is pumped through coffee grounds.
3. An oscillating pump with or without external thermostat.
4. A steam valve with a knob to open & close steam/hot water outlet.
5. Thermostat to limit temperature of water or steam.
Limit for espresso water temperature: 90°C to 98°C
Limit for steam temperature: between 127°C to 152°C.
6. A thermofuse to shut power supply when temperature in the boiler exceeds the higher limit (usually 185°C).
7. Solenoid valve (selected Gaggia models only).
8. A filter cup holder handle to place ground coffee for extraction of espresso.
The pump models generally are easy to open. In most brands, the top cover is fixed with two to four screws. In the Barista/Rio Vapore models, the top cover curves around to the back and the top has two screws. The front end has about 1/3" 90 degree fold. This folded lip is wedged between two plates. It may be necessary to use a long screw driver or other rod, pushed under the top cover, alternatively on either side of the machine to nudge the cover free and lift up. Note the slide along the left side in the picture below. Once the top cover is taken off, the entire internal set up can be viewed. The pictures below show two popular models:
1. Gaggia Model Espresso (without solenoid valve)
2. Saeco Espresso Classico (rapid steam model)
If you find this helpfull please remember to vote for it
Coffee Makers & Espresso Machines Logo
Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Jun 16, 2009 | FrancisFrancis! X5 Espresso Machine
where do i get gaskets for FrancisFrancis X1?
The Francis Francis machines are owned by illy now - you can get parts from them - 1-877-469-4559
-Tha Mp3 Doctor
Nov 12, 2008 | FrancisFrancis! X1 Espresso Machine
that replacement Saeco-Francis-Francis element
I picked up my Saeco element for my X1 repair at this location in Ricmond, British Columbia, Canada. They carry the part in stock.
www.espressotec.com/
The part was 48 CDN dollars.
Sep 01, 2008 | FrancisFrancis! X5 Espresso Machine
2,663 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
