Tip & How-To about Computers & Internet
How to locate your IP address in Windows 7
Find your ip address in windows 7.
1.
Click the start menu.
2. Type "CMD" in the field and click the enter button.
3.
Type the word "ipconfig" at the end of the first line of text.
4.
The results should be returned.
See the visual reference here
Computers & Internet Logo
how to find my ip address on windows 7
You can find your IP address on windows 7,by following the below steps:
1.Start->Run->cmd prompt
2.In that,just type ipconfig and then click enter
For example: It will show ip address like 74.110.208.65
If you want to find your network ip address that is provided by your ISP,visit Ip-details.com .
Mar 30, 2013 | Black Box IP Address Translator With...
IP Address
What ip address you need and on what operating system ?
For windows, press the "windows key" (the one with a flag) then type "cmd" and press enter. At the command prompt that appears, type "ipconfig" and press enter. You will find your intrernal ip address there.
If you need your external ip (as seen from internet), open your web browser an go to www.whatismyip.com .
Your external ip will be displayed there.
May 07, 2011 | Computers & Internet
Can't connect to router by wireless and by local area connection with cable, it just saying limited or not connectivity, even after router reset.
Locate the MAC Address for the Computers You Want to Use for Gaming
1. Click the Start button.
2. Click Run.
3. In the Open box, type the following text:
cmd
4. Click the OK button.
The command prompt screen appears.
5. At the command prompt, type ipconfig /all
6. Write down the MAC (Physical) address of your computer to configure for gaming.
Change Router Settings
1. Open a web browser, and type http://my.router, or http://192.168.2.1. The Enter Network Password login prompt appears.
2. Type the following text in the user name and password fields: "admin".
3. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
4. Click the DHCP Server Settings menu option in the drop down menu.
5. Click the Add button in the IP Address Reservation section.
a. Enter the MAC address of the computer you wish to use for gaming in MAC Address field.
b. Enter an IP address for the computer.
6. Click the Submit button.
7. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
8. Click the Port Forwarding Settings menu option in the drop down menu.
a. To set a single computer for gaming, click to select Enable DMZ Host.
b. Enter the IP address of the computer in the DMZ IP Address field.
c. Click the Submit button.
NOTE:
Only a single computer can be set for DMZ service. To set multiple computers for gaming, please refer to the Custom Port Forwarding Settings under Port Forwarding Settings.
9. Reboot the client computer. The client computer will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
Oct 28, 2010 | Dell Wireless 2350 Router
looking for default IP adress for my cnet car 854
1. Connect your router to your computer via ethernet cable
2. Now we will check the IP Address
Windows XP
1. Click "Start"
2. Click "Run"
3. Type "cmd" without quotes
4. On the black screen type "ipconfig" without quotes
5. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
Windows Vista
1. Click "Pearl button" (Start button in XP)
2. Click "Start Search"
5. Right click the black icon up at the top of the window
6. Click on "Run as administrator"
7. Click on "Continue"
8. On the black screen type "ipconfig" without quotes
9. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
I hope this helps you.
Jan 06, 2010 | Cnet Wireless-G CAR-854 Router (CAR854)
IP DETAILS
well this question has 2 answers:
1) if you want to find out what is the ip that in on your PC if you are connected to a one of these (cable modem, DSL modem or router) then this is what you call a "local ip, or private IP" to check it you do this: you click Start/ run/ and you type CMD and press ENTER on the keyboard. then in the black window you type "ipconfig" (without the quotes) and you press ENTER again. here it should say, ip address (most likely it is going to start like 192.168.xxx.xxx , where xxx could be any set of numbers)
2) if you are talking about the IP address that your modem (cable or DSL) is pulling , that means that is your "public IP" and to find it out, (the wasiest way) you can go to a site like "whatismyip.com" and your public ip will be at the top of the page.
Note: in case of vista, to get the black window you click "start/(start search) and type CMD and enter"
the rest is the same.
Jun 18, 2009 | Computers & Internet
164 people viewed this tip
David Payne
David Payne
