Tip & How-To about Computers & Internet
Edit Flip Video in iMovie-Import Flip Video to iMovie and Edlt Flip Video iMovie
Flip videos have now become very popular among users who want to shoot easy and fast videos. And quite a lot of these users are using Mac OS and need to edit flip videos in iMovie on their Mac machone; however, flip videos cannot be directly imported to iMoive and to edit flip videos using iMovie, you will have to convert flip videos to iMovie supported formats. Therefore, there are the following two parts to edit flip video in iMovie
Part One: Import flip to iMovie
Since flip videos are not supported by iMovie, you will need a converter. Doremisoft Flip Converter is a very practical and easy to use Mac application for users to convert flip to iMovie video formats. Click here to download this application and follow the steps below to convert flip video to iMovie:
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in iMovie to Doremisoft Flip Converter.
Step 2: Select an iMovie format for your conversion
Click the Profile drop-up list and select an iMovie format to convert your flip videos.
Step3:Convert flip video to iMovie
Click the "Start" button on the lower right of the interface to start converting flip video to iMovie.
Part Two: Edit flip video on iMovie
Now your flip videos have been converted to iMovie supported video formats. Launch your iMovie and follow the steps below to edit your flip videos:
Step 1: Import the converted flip videos to iMovie
Select "Import Movies" from the File menu and use the browser to select the converted flip videos. You can hold down the "shift" button to select and add multiple files. Then click on the "+" button of your iMovie to create a new project, and name this new project.
Now you can see the imported videos in the video clips section of the iMovie. Drag and drop them into the timeline of iMovie.
Step 2: Arrange video orders
Drag and drop the video files in the timeline to arrange them in the order you prefer.
Step 3: Select transitions
If you want to apply transitions to the added videos. You can select "Transitions" at the Window menu, select the transition you want and drag it and drop it between any two scenes.
Step 5: Set start and end
Click on the click icon to switch to the timeline view. Here you can trim your arranged clips for more precise editing. Simply use the Playhead bar over the timeline and select your stop and end points.
Step 6: Crop and adjust video
Select one video clip and click on the Crop button to crop it. Select one or more videos, and click on the Video Adjustments icon to adjust the video effects.
Step 7: Other editing
The editing tools also allow you to add text, effects, and audio effects. You can try out and play around with these tools to see how you want to edit your videos.
Step 8: Export your movies
Click the "Share" menu and select "Export Movie" to export your movies. Now you will see the "Size to export" window, select the size according to the references shown on this window, depending on which devices you want to export your movies to.
iMovie seems to be more than enough for us to do the editing and it is not very easy to use. Actually, you can also use Doremisoft Flip Converter to do some easy editing. Click here to see how.
Computers & Internet Logo
can't upload videos to Imovie
Kodak series cameras capture videos in MOV files. iMovie will only import codecs that it can edit. iMovie can import MP4, DV, Apple Intermediate Codec, H.264, Photo JPEG, Motion JPEG, Apple Animation, and perhaps others. MOV is a multimedia container file, not a codec. It can contain any of the above codecs, but it could contain other codecs that are not editable by iMovie, such as MPEG-1 or MPEG-2 so that sometimes iMovie cannot recognize Kodak videos directly.
please try this video converter, good luck. kodak video to imovie
http://www.kodak-video-converter.com/how-to-importedit-kodak-video-into-imovie-on-mac.html
May 04, 2009 | Kodak EasyShare V603 Digital Camera
How to edit flip video with Mac Flip Converter on Mac OSX? Flip Video is a popular camcorder among young men due to it's easy-to-take and non-expensive spending. We can shoot fantastic movies and get the mp4 file type from flip mino, flip ultra, flip mino hd, or flip ultra hd. Although it is popular, not everything is perfect. However, flip video editing is an issue that has been plaguing a lot of flip video users. Mac Flip Video Converter provides you with the easy flip video editing. It can crop flip video, trim flip video, edit flip video effects and merge multiple flip videos into a single file. How to edit flip video with Flip video Converter for mac? Before you start to convert, make sure that you have downloaded and installed Flip video converter for Mac on your computer. Merge multiple flip videos into a single file Select the flip videos you would like to merge, click the "Merge" button, and the selected flip videos will be merged into one file after conversion. Tips:You can hold down the shift key on the keyboard to select multiple flip videos. Trim flip video If you want to remove the unwanted footages from flip videos,click the "Clip" tab to trim flip video to take the part you want from a flip video." "Tips: You can use the "Merge flip video" function to take different parts from one flip video and combine them together into one file. Edit flip video effects Click "Edit"->"Effect",and set the brightness,saturation,contrast as you like.You can also set special video effects including old film,grayand emboss to adjust flip video. Crop flip video Click the "Edit" button on the main interface, and it will go to the "Crop" Window by default.In this interface,your can cut off unwanted video sides or zoom in a part that you want to emphasize from your flip video. You can efficiently edit flip video and better enjoy them with the above easy flip video editing steps. If you want to do more editing, you can import flip video to iMovie using this application to further edit your flip videos.
Sep 17, 2010 | Computers & Internet
162 people viewed this tip
David Payne
David Payne
