Tip & How-To about Hand Tools
Ball driver Allen wrench ball broke off in bolt head
If you ever break off the ball end of a ball driver allen wrench:
1. With a scribe, dental tool, or small punch try to free ball so it is loose in the bolt head.
2. Try a magnet. If this doesn't work........
3. With compressed air, shoot air directly at ball with air nozzle.
The air gets behind ball and it pops right out if the ball is free enough.
Hand Tools Logo
How to Remove Drill chuck from LxFD01 Makita drill
The screw in the bottom of the chuck is reverse threaded (left tight, right loose). It is also lock-tited so will be hard to remove. Make sure you have a screw driver well seated in the screw and turn it backwards (clockwise) to break it free. Once that is out, lock the short end of an allen wrench (at least 3/8" to 1/2") in the chuck. You'll have to lay the drill on a bench with the long end of the allen wrench hanging over the edge so you can hit it with a hammer hard enough to break the chuch free from the anvil. The chuck is threaded left loose, right tight so hit the wrench to turn the chuck counter clockwise. When you replace the new chuck use a small drop of lock-tite on the anvil threads and screw if it doesn't have some on it already.
Jan 22, 2013 | Makita LXFD01Z 18V LithIon Cordless 1/2-In...
how do you take the chuck off makita bhp 451
After removing the screw lock the short end of a 3/8" to 1/2" allen wrench in the chuck. Firmly hold the drill on the edge of a bench or lock it in a vice so you can strike the allen wrench hard and fast. The screw is reverse threaded but the chuck turns lefty loosy like a regular nut and bolt. It's the best and only way to break the chuck free.
Sep 06, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
cant get the bad chuck off my RIDGID 18v cordless hammer drill
The chucks on these drills are put on not only VERY tight but usually with some lok-tite to boost so they don't come off easy. In my shop we usually lock a 1/2" hex driver in the chuck and use a 1/2" impact wrench to knock them loose. It usually takes a few seconds to come loose. Another method is to lock the short end of a 1/2" allen wrench in the chuck so that it sticks straight up with the drill standing up. Then lay the drill on its side with the top at the edge of your bench and the allen wrench sticking over the side of the bench. NOTE: The chuck follows the lefty-loosey, righty-tighty rule, the chuck screw is reverse thread. Have someone firmly hold the drill and then hit the end of the allen wrench until the chuck comes loose. Once you break it free it will spin off easily. You do need to put the new one on with lok-tite and as tight as you possibly can then lok-tite the screw and tighten it as much as you can by hand.
Jan 20, 2012 | Ridgid Drills
need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I have a DeWalt DW 235G drill that needs a new chuck. How do I get the old one off. I took out the screw ...then what?
Put the small end of a 1/4" allen wrench in the chuck and close the chuck on the wrench the place the drill on your bench with chuck hanging over the edge and hit the allen wrench with a hammer and it will shock the chuck loose. Hold on to the other end of the drill when hitting allen wrench.Reverse for reassembly
Jan 24, 2010 | Dewalt Drills
635 people viewed this tip
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
