Tip & How-To about Washing Machines
Removing Grease & Butter Stains
Before Washing your Garment, Place Ultra Palmolive Oxy Plus Dish Detergent on the spot. Rub it in with a toothbrush or with your finger real well till it is coated. Wait 10 Minutes and wash as normal. Stain should come right out of garment. This may Be done a second time before drying if necessary, but should not need to be.
Washing Machines Logo
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
Can you add soap directly on clothes before starting to the load? Does it matter?
Most people add soap directly to stained place there trying to get clean. So my answer is yes. The only think you don't want to put directly on cloths is real bleach. Landry detergent with bleach alternative is ok...like oxy-clean.
Aug 15, 2013 | Kenmore Washing Machines
if rahul gandhi is the primeminister of india?
Dr. Manmohan Singh is the current Prime Minister of India. Rahul Gandhi is the son of Rajiv Gandhi, former Prime Minister of India and Sonia Gandhi, the current Congress President. His grandmother was Prime Minister Indira Gandhi. In 2004, Rahul Gandhi was elected to the Parliament of India.
I am not sure how this relates to Colgate Palmolive dishwashing detergent, unless you are trying demonstrate some kind of link to an obscure comment made in 2004, after he won his seat in Parliament that " Gandhi detergent washes away caste".
I doubt that this is the appropriate forum for any type of political discussions or references.
Feb 16, 2011 | Colgate Palmolive CPC 46076 Palmolive...
What is the safe way to clean it?
Wash in the sink with a toothbrush and normal dish detergent. Don't place in the dishwasher because the food particles will get into the machine. Difficult spots, clean with white vinegar only.
Aug 30, 2010 | VillaWare Al Dente Pasta Machine Chrome...
The beater shaft is stuck, can't get the flat beater off. How can I fix this?
Try some oil... ...or liquid dish detergent on a wet rag and rub around that area..
Aug 29, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
182 people viewed this tip
Top Washing Machines Experts
