Tip & How-To about Computers & Internet
How to convert video to ipod
While the Apple iPod isn't the first portable device to support digital video playback, it's probably the one device that will push portable video into the mainstream. Of course, a key draw of the iPod as a portable video player (PVP) is the fact that its complementing software, iTunes, offers a cheap, easy, and legal way to get content that will play on the device. But what if you already own the video files you'd like to watch but don't play back on the iPod? You could use Apple's simple QuickTime Pro tutorial (you'll need the $29.99 QuickTime Pro 7), but then you'd be limited to the file types that QuickTime supports. If you want the ability to convert from the full gamut of video file types, check out the tutorial below.
Before you start, you'll need to gather these elements:
AVS Video Converter (free to try, $29.95 to buy; Windows only)
Video files, almost any size, shape, or format
Video-capable iPod
Follow these simple steps
1.Download AVS Video Converter.
You can try out the Windows-only Video Converter for free, but a watermark will appear throughout your video. If you're serious about converting video, purchase the program for $29.95; the variety of supported file formats makes it worth it.
2.Launch AVS Video Converter.
3.Select output file type.
Click the To MOV button along the top of the interface. When creating a video for the iPod, always select the QuickTime file format (MOV).
4.Choose video file.
Click the uppermost Browse button on the right. Navigate to the location where you keep your video files, and select the video that you would like to convert. Click Open.
5.Select the output location.
Click the bottom Browse button on the right. Choose the location where you would like to save your converted video file. Click Save.
6.Adjust the settings.
Click the Edit Profile button on the right and fill in the following information:
* Name: QuickTime--for iPod
* Description: Video: MPEG-4, FrameRate: 30 fps, Frame Size: 320x240, Audio: AAC LC - 128, 44100, Stereo
* Comment: (optional)
* Video Format: MPEG-4--high quality
* Frame size: 320x240
* Audio Format: MP2/4(AAC LC) 128Kbps
* File Type: MOV
* Framerate: 30fps
* Width: 320
* Height: 240
* Frequency: 44,100Hz
* Channels: Stereo
7.Convert video.
Click Convert Now and step away from the computer (processor performance will be seriously affected during conversion). If you want to watch the progress while you convert, click the Advanced button until the viewing screen pops out of the bottom.
Note: AVS converted our original 22-minute MPEG-4 file at a rate slightly faster than real time on an Intel 2.8GHz P4 system with 1GB of RAM. Our source file was 224MB, and our resulting iPod-compatible file was 199MB.
8.Transfer video to the iPod.
Open Apple iTunes and drag the newly converted video file to the library window. If you have selected "Automatically update all videos" for the video preferences for your iPod, the new video will automatically transfer when you connect the player. If you have selected "Automatically update the selected playlists only," make sure that you drag the new video to one of the selected playlists.
Note: You'll probably want to update the information of the video when you move it to the iTunes library. To do this, select Videos from the left-hand column and go to list view. Then, click the file for which you want to edit info and select Get Info from the File menu (or simply right-click). You can edit the boxes found under the Info tab.
Computers & Internet Logo
how to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
hi i just dont know how to convert my videos to my go gear device how can i put some videos
I think you need a third party software, just convert your videos to the format which support by your player.
Here is a detail tutorial about how to convert almost all popular video formats even high definition video for playback on your portable multimedia players such as iPod touch/video/nano/classic, Zune, iPhone, Apple TV, PSP, Xbox 360, PS3, Archos, iRiver PMP Player, Creative Zen, Pocket PC, and Mobile Phone etc.
http://www.dvd-ripper-copy.com/guide/video-converter-guide.html#195
Nov 26, 2009 | Philips GOGEAR SA6045 MP3 Player
cannot play video
This model (iPod 2nd Gen) does not appear to have video playback or video out capability.
-=/ MLF /=-
Oct 20, 2009 | Apple iPod nano
i want to download transcend mtv converter software to store vedios in ma ipod. i hav t.sonic 850 8gb ipod
Jus t try to use Leawo MKV Converter!
http://www.leawo.com/mkv-converter/
Leawo MKV Converter lets you make the most of MKV videos by converting MKV video to any popular formats, for example, MKV to AVI, MKV to MP4, MKV to DVD, etc. With this powerful MKV video converter, you can handle any MKV videos with different resolutions, e.g. 720p and 1080p, and convert them to be playback-ready on iPod, iPod Touch 4, iPhone, iPhone 4, PSP, Apple TV, Apple TV 2, Windows Mobile, Android Mobile, Zune and more media devices.
Aug 11, 2009 | Transcend T.sonic 850 Digital Media Player
ipod video playback
change the file format. mine did this. download something called PSP VIDEO 9. it's so easy to work, just upload the video, it converts, and save it, then re open it with iTunes & re connect iPod
Nov 25, 2007 | Apple iPod MA446LL/A MP3 Player
168 people viewed this tip
David Payne
David Payne
