Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
Copy a Group of Cells in Excel 2007 to the Clipboard as an Image
If you want to share a small part of your Excel worksheet but don't want to send an Excel file, you can copy part of the worksheet to the clipboard as a picture instead, which can be pasted into any application that supports images, such as your favorite image editor.
The command in Excel 2007 to do this is oddly located on the Paste menu in the Ribbon. From the Home tab, click on the drop-down menu under the Paste button, and select As Picture \ Copy as Picture.
Now you will get a dialog asking you how you want to copy the picture. If you want to paste the picture into any application, you'll need to select "As shown on screen", and then "Bitmap".
Now your cell data should be on the clipboard, ready to paste into any application that allows you to paste in a bitmap. Here's an example of a bitmap I pasted into the editor I use for writing articles here:
Very useful!
HP Pavilion a1410n (ER890AA) PC Desktop Logo
I want to copy an Excel chart as a Image onto a PowerPoint Slide (Office 2007). What is the sequence of APIs to apply?
Copy worksheet data to a PowerPoint presentation
  1. In Excel, select the worksheet data that you want to copy to a PowerPoint presentation.
  2. On the Home tab, in the Clipboard group, click Copy za006044679.gif.
Keyboard shortcut You can also press CTRL+C.
  1. Click in the PowerPoint presentation where you want to paste the copied worksheet data.
  2. On the Home tab, in the Clipboard group, click Paste.
Keyboard shortcut You can also press CTRL+V.
  1. Click Paste Options za006043532.gif next to the data, and then do one of the following:
    • To use the original format of the copied data, click Keep Source Formatting.
    • To use the document theme that is applied to the PowerPoint presentation, click Use Destination Theme.
    • To paste table data that you copied as text, click Keep Text Only.
Notes
  • If you don't see the Paste Options button, you may have to turn it on. Click the Microsoft Office Button za010077102.gif, and then click PowerPoint Options. In the Advanced category, under Cut, Copy, and Paste, select the Show Paste Options buttons check box.
  • If you paste the data into a PowerPoint table, the Paste Options button is not displayed.
Tips
  • To paste the data in another format (such as a worksheet object, HTML format, bitmap, picture, or to text format) or to paste a link to the source data in Excel, on the Home tab, in the Clipboard group, click the arrow on the Paste button, and then click Paste Special. In the As list, click the format that you want to use.
    • If you want to edit the entire worksheet later, click Microsoft Office Excel Worksheet Object. Clicking Microsoft Office Excel Worksheet Object provides access to the entire worksheet in the presentation, including data that you may want to keep private. To automatically update the table in the presentation when changes are made to the source data in Excel, click Paste link. Both of these options also preserve the Excel formatting, even when the formatting features that are used are not supported in PowerPoint. If you saved the source workbook before you copied the data, you can also click Attach Hyperlink to insert a hyperlink in your presentation that directs you to the source data in Excel.
    • To paste the content as an Object Linking and Embedding (OLE) (OLE: A program-integration technology that you can use to share information between programs. All Office programs support OLE, so you can share information through linked and embedded objects.) PowerPoint application icon (rather than pasting the actual content), click Microsoft Office Excel Worksheet Object, and then select the Display as icon check box. You can click the icon to open the application and then view the content.
    • If you want to use HTML to copy the data to PowerPoint into a PowerPoint table, click HTML format.
    • To paste a static picture, click Device Independent Bitmap or Bitmap, or to paste a picture that can be ungrouped, click Picture (Enhanced Metafile) or Picture (Windows Metafile).
    • To paste the data as formatted or unformatted text, click Formatted Text (RTF) or Unformatted Text.
  • To paste the data as a hyperlink that directs you to the source data in Excel, click the arrow on the Paste button, and then click Paste As Hyperlink. If the workbook that contains the source data has not been saved yet, this option is unavailable.
  • If you want the range of data that you paste as a Microsoft Excel Worksheet Object into a PowerPoint presentation to expand when the corresponding data expands on the Excel worksheet, you can define a name (name: A word or string of characters that represents a cell, range of cells, formula, or constant value. Use easy-to-understand names, such as Products, to refer to hard to understand ranges, such as Sales!C20:C30.) for the range of data in Excel before you copy the data. You can then paste a link to the named range by using the Paste Special command. On the Home tab, in the Clipboard group, click the arrow on the Paste button, click Paste Special, and then click Paste link. This works only when you copy data that is not in table format in Excel.
Mar 09, 2011 | Individual Software Professor Teaches Word...
how can enable mail recipient as attachment excel
MAIL RECPEINT AS ATTECHMENT OPTION NOT VISIBLE IN MY OFFICE 2003 PROFESSIONAL
Apr 11, 2009 | Microsoft Office Excel 2003 for PC
How to copy Excel worksheet in a word document?
go to Insert > File >select file and insert.
you have to select all documents when you when insert box opens.
Mar 15, 2009 | Microsoft Excel for PC
import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Jun 10, 2008 | Microsoft Office Access 2003 (077-02871)...
MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Apr 29, 2008 | Microsoft Excel for PC
2,716 people viewed this tip
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
