Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
Make Windows Vista Explorer Preview Pane Work for More File Types
The first thing we'll want to do is navigate down to HKEY_CLASSES_ROOT\.reg. Once we are there, we need to check the value of the (Default) key to figure out if there is a ProgID registered, and what the name of it is.
The ProgID is used so that multiple file extensions can have the same settings without duplicating information in the registry. This way the .reg and other keys can point to the "regfile" ProgID to get all their settings
next you'll need to browse down to the ProgID key, where we'll actually apply the hack: HKEY_CLASSES_ROOT\regfile. Once you are there, create a new key called shellex under it, and then create another key under that one with this name:
{8895b1c6-b41f-4c1c-a562-0d564250836f}
This key is the unique ID that tells Windows Explorer you want to set a preview handler. Once you've created that key and selected it, you'll see a new (Default) key on the right hand side which you'll want to modify.
Double-click on the (Default) key, and use the following text for the value:
{1531d583-8375-4d3f-b5fb-d23bbd169f22}
This key is the unique ID for the Windows TXT Preview Handler, which I figured out by looking under the list of currently registered Preview Handlers in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\PreviewHandlers
You could substitute any one of these preview handlers… if you wanted to register a media file preview handler, you could use {031EE060-67BC-460d-8847-E4A7C5E45A27} as the value instead of using the preview handler for text files.
At this point, you should be able to select a .reg file and see its contents in the Preview pane:
his same method would work for any other file type, but that could get really tedious.
Adding Preview File Types The Easy Way
Now that we know how it all works (or not, as you probably skipped down to this part), you can use the free PreviewConfig utility for Windows Vista, which is just extremely simple to use. Just select the file type on the left, and then select the handler you want for it on the right.
HP Pavilion a1410n (ER890AA) PC Desktop Logo
Samsung SGH a727 forgot password to turn on phone
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Sep 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
how to rename recycle bin
I'm am sorry I am a little confused, you want to rename the recycle bin Registry key, but not rename the actual recycle bin? I need a more detailed explanation of the problem that is very specific. Also, just out of curiosity, why do you wish to rename the recycle bin? I am just curious.
Ryan Frame
Creative Energy Associates Technical Center
Aug 22, 2009 | Nolo How to Change Your Name in California...
Samsung sgh-A727 and I cant remember the power on password
Mar 11, 2009 | Samsung SGH-a727 Cellular Phone
invalid syntx error
The cause of this issue
CAUSE loadTOCNode(1, 'cause'); This behavior may occur for one or more of the following reasons: • The (Default) value setting in one or more of the following registry keys points to an incorrect location for the Urlmon.dll file: [HKEY_CLASSES_ROOT\CLSID\{79eac9e0-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f1-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f2-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]This Behavior May Occur if you install a customized version of Internet Explorer that was created with the Internet Explorer Administration Kit (IEAK) version 5.01 Service Pack 1 (SP1), 5.5 SP1, or 6.0. • The following registry key is missing or damaged: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046} • One or more of the following files is missing, damaged, or improperly registered: • Urlmon.dll • Mshtml.dll • Actxprxy.dll • Oleaut32.dll • Shell32.dll • Shdocvw.dll
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem in Internet Explorer, follow these steps: 1. Quit all programs that are running. 2. Click Start, and then click Run. 3. Type regsvr32 urlmon.dll, and then click OK. 4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below): • Shdocvw.dll • Actxprxy.dll • Oleaut32.dll • Mshtml.dll • Browseui.dll • Shell32.dll Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
If the problem is still not resolved, verify that the following registry values are present and correct: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}
Value: IDispatch
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid
Value: {00020420-0000-0000-C000-000000000046}
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid32
If the problem is still not resolved, reinstall Internet Explorer. If you are using the version of Internet Explorer that is included with your operating system, reinstall or repair your operating system.
Thanks
Riz
Mar 21, 2008 | Microsoft Windows XP Home Edition
2,287 people viewed this tip
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
