Tip & How-To about Computers & Internet
Recods Recods or taps to MP3 File foremat
I have found a turntable called ION PROFILE Pro It connects to your USB connection and can rip your records or tapes to MP3 songs. It have an input for cassette tapes or 8 track tapes it also alows you to store them then in digital format. t can connec to 8 tracks cassentt tspes and has a plug in to plug into your sterero system and can paly records as well. You can connect it to your stero system and if yo have a mp3 device for your video recored you can recod music here as it has a volumr control as well. It uses software called aduacity that converts vinal taoe ti mp3's and ajudio converter that allows you to burn music in standard music format. This is an inexpensive set up and costs $79.00
Computers & Internet Logo
Why do I not get full stereo spectrum on Ion Profile Pro turntable when connected to Dell computer?
This toy player, can be used with a USB cable, but also with tulip plugs. When you have an amplifier, you at least can test if the sound coming from the element is in stereo. If that sounds good, you know there could be something wrong in the A/D convertor in the record player, or still your computer can't handle the digital signal coming from the USB connection.
Here I found a Video, where they use the analog output and connect it to a pair of computer speakers direct.
Ion Profile Pro USB Turntable Review
Jan 22, 2015 | Audio Players & Recorders
how to connect ion turntable to bose radio?
Why whole you try to connect a computer accessories to an audio system? Even when both things are made for audio.
To bring digitising vinyl, closer to the computer user, ION produces record players, which don't output audio signals, but digital signals.
The digital signals can be read by a computer, when connected to a computer with the appropriate software installed.
If you want to connect the record player to an audio system, you need to rip it down. Trow out the digital part, and connecting correct cabling, straight to the cable coming form the PU element. Then you will be surprised, how little modern amplifies still can handle the low signal levels a PU element produces.
I'm sorry I have to say you can't use the ION turntable in a normal audio system, like you can connect any USB connector to a normal audio amplifier, unless you modify the whole system. And if you would modify, the sound coming form that system, would sound poor, considering what you have to pay for the ION, and the modification. A normal record player, with a correct pre amplifier that can be connected to the Bose, would be cheaper.
Jan 01, 2015 | ION Profile Pro Lp Usb Turntable With...
not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded version. it's very frustrating when you know what your supposed to be hearing and it just isn't there. I have a Ion profile pro usb recorder. Have you heard of anyone else with the same complaint?
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
156 people viewed this tip
David Payne
David Payne
