Tip & How-To about Coffee Makers & Espresso Machines
Keuring coffee maker B60 B70 B77reservoir full but fails to refill, brewing half-filled cups
After a brief investigations found out that this is a design problem for all the newer Keurings like B60, B70, B77, Keuring factory after a lot of complains of a noisy refill pump this is the pump which pressed water from reservoir tank into the brewer. (Please to mixed it with the second pump that presses the hot water through the K-cup this is a different one).
In the place of that pump now they are using a small DC motor and impeller pump, which is much quieter however the new design just won’t work.
It seems that we have air that gets into the system and the new pump isn’t strong enough just to SELF-PRIME with this way. With this way the motor still runs, runs, runs but water is not going through it and finally it turns itself OFF in order not burn out. Normally it should take only few second to refill the brewer tank.
There were many options that the problem was due to the check valve located in the base of the unit just below the reservoir seats itself. However actually this small new pump cannot press hard enough to open the check valve so the water can easily flow. If there is air in the system or slightly scale this make it harder.
I have found out that that the problem occurs only just a few weeks after we use a brand new machine.
So one very good way to solve the problem is to turn the machine on and lift the water reservoir up just a couple of inches and then jam it back in place fast and hard. With this way is like it injects just enough pressure into the system to open the check valve and when the motor pump will run you will realize that immediately water will passing through from reservoir to brewer tank. This procedure has to be done often between cups.
From what we seen in internet their hundreds about the same problem but we have not see any serious response about it From Keurings customer service yet.
One other important and related problem frequently reported is the irregulars doses of coffee like HALF-FILLED CUPS of coffee e.t.a
This must be redesign from Keuring factory since there is not much we can do about it to solve once for all even if they will replace your machine with a new one you will have the same problem in few weeks. And definitely this not a problem due your Electricity in your area or due to hard water. However hard water areas will face bigger and more intensive the above problem so one more suggestion is to decaling the machine every week this will help a lot.
If you find the above helpful please remeber to vote for it
Coffee Makers & Espresso Machines Logo
My keuring B70 is dispensing about half of a cup of coffe , sometime it shuts itself off.
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Aug 15, 2010 | Keurig Platinum B70 Coffee Maker
need manual for B77 model
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Mar 31, 2010 | Keurig Platinum B70 Coffee Maker
How to disassemble a Keurig B60?
I can't tell you that but I can point you to replacement parts dealer. The best of luck to you, Hope it helps:)
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Mar 29, 2010 | Keurig B60 Coffee Maker
need new k-cup holder for keurig B70
most parts for Keurig b30, b40, b50, b60, b66, b70, and b77 In stock.
Nov 15, 2009 | Keurig B70 Coffee Maker
15,753 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
