Tip & How-To about Computers & Internet
FREE INSURANCE for PHONES, LAPTOPS etc- DON'T PAY!!!!
Tried this many times- and works great!!!
Orange- you've smashed your blackberry, and as it's 'wear n tear' it's not covered by the manufacturer guarantee, and you don't have insurance! No worries... phone orange, and tell them your button doesn't work which is affecting your phone's operation, and bob's your uncle, they'll arrange an exchange (usually within next day)... they'll give you a brand new blackberry whilst you give them your smashed one... & BEST THING- They NEVER EVER do any checks, so be careless as many times as you want, just blame it on the workmanship!!
I've also used this tactic with getting free equipment from DELL, & TOSHIBA...
Try it, and rate me!!!
Computers & Internet Logo
Need to know if its normal for an Xtrail clutch to burn out at 69000 km. If not, why would Nissan not cover it under the manufacturers warranty?
A clutch, like a tire and brakes, is a wearable item and simply not covered under warranty. Some clutches last longer than others but that is because of the way it is used. A clutch that is "ridden" will wear out faster than one than is not. And when you replace the clutch, you will have the same wear pattern with the new one unless you change your riding/driving habits.
Aug 05, 2016 | 2005 Nissan X-Trail 2.0
My front Master Cylinder doesn't work. I've already tried bleeding the brakes and there's no pressure even drawing the fluid through the line. Any ideas on how to fix this?
I'm going thru the same thing...I blew air in the line with pressure and the caliper worked...open heart surgery master cylinder and caliper and no signs of wear and tear...to me its like if the master cylinder doesn't have enough pressure to push the brake fluid......my conclusion ..faulty master cylinder...
Apr 04, 2012 | 2000 Yamaha V Star Classic
My psp wont start! When i Charge it will just show the orange light at the right but it wont charge.Then when i try to start it will only show me some little light then it will just turn off. I already tried to play it without an battery but still it still wont work. Can somebody help me
If it's an old model, say more than 5 years, it's probably just wear 'n tear. Products stop working all the time because they are mass produced, there is a lot of room for error, especially for anything electronic. My best advice would be to call Sony and see if they will cover it under warranty.
May 02, 2011 | Sony PlayStation Portable (PSP) Console
Remotes worked great, then...The (RKE) remotes only worked sometimes. I thought the batteries where low so I replaced on both RKE remotes, then more problems. Sometimes it opens the doors, sometimes it starts the car, mostly they don't work at all. I tried resetting them through the DIC center, but still only works sometimes. Then just yesturday, my drivers door only unlocks or locks sometimes and the power button on drivers door quit working.
Take it back to the dealer. Manufacturers have a code of practice that says that they warrant cars for three years on parts that not subject to normal wear and tear (brakes, tires etc). The problem is electrical and therefore not part of the component list subject to wear and tear. If you get no joy from the dealer take it up directly with GM. Buick have been building a reputation for reliability and quality construction so they should be keen to keep you happy on what is such a young car
Aug 20, 2010 | 2008 Buick Lacrosse
pgr 30 oven takes a long time to heat up
Hot surface Ignitor is bad most likely. Normal wear and tear. You can check it by looking at it, it should be black. If it's white, it's no good.
Dacor oven repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Dacor Preference PGR30SS Gas Kitchen Range
164 people viewed this tip
David Payne
David Payne
