Tip & How-To about Cameras
Facing the photography, we can also have the dynamic relationship because hand mix, make the photo shoot quality declines, now I will share the three skills, the hope can effectively improve the quality with our photos.
A correct posture
Most photographers Fujifilm BC-70 Digital Camera Battery Charger position are almost, but often ignore the importance of body posture. Many people with arms, the body to maintain stability of the camera. Correct posture is lifted weights, like most, best method is to use your legs for weight, so need to adjust your feet posture, in order to adapt to the following several principles
1. Use both hands holding the camera. One hand, left hand hold lens and control the shutter. Hold fuselage
2 and keep the step forward undergone knee. This can be its weight evenly in both legs. Distribution
3 set up your camera shooting posture of general. For digital SLRS is lifted in the viewfinder will (note: before the right frame, the translator is left with another advantage, and for details) portable digital camera is lifted in the face of former 15cm around eyes flat position.
4. Two arms clamping body. Left forearm should remain completely vertical, and can't move beyond the toe. Must avoid body, otherwise it will cause camera shake.
5 breath, in between two breaths (note: can also holds gas but cannot too long) as gently press the shutter.
B. carry tripods
The tripod very not easy to carry, the skills you weak light on how to use when shooting environment with feet.
In filming, cut out before you and a height of rope, almost in pockets, or go in.
2 in the filming site, the end in the camera, let the other side down on the ground.
3 a foot continually on the rope, then slowly raise the camera to the eyes. Carefully rope strung straight, but be careful not to affect greatly too forcibly airframe and lens interface.
4 when a rope strung straight after, as described in article 1 skill that pose, gently pressing the shutter button.
C) the ChiFa hold some Joe Fujifilm FinePix J37 Digital Camera Battery Charger
With rapid modifying techniques of famous photographers Joe some pictures for the press, often, for instance, the sports pictorial ", national geographic, and the life magazine etc. Although in light of shooting, but he seldom use a tripod. Contrary, he has his ChiJi method. This method with left point. After a little practice, this method can be used to ChiJi photographer speed shutter photography. Note: this method (some of the levites in Joe diary book hot boots are detailed and applies only to illustrate the camera is vertical shooting handles.
Step 1. The pose and article 1 skill in his left foot in the same before, and shoulder are the same as wide.
2. Turn left shoulder, make body toward the body.
3 ChiJi phase, with the right hand in his left shoulder and body frame of depression, connected clavicle below.
4 to hand in hand together with Fujifilm FinePix J30 Digital Camera Battery Charger fixed live camera. Keep the body weight distribution in two feet, with my left eye look through the viewfinder. After pressing the shutter button breath.
