Tip & How-To about Computers & Internet
One of the core notebook hard disk used correctly
One of the core parts of the notebook hard disk, the importance of the correct use and is not only can prolong maintenance service life, the hard to avoid missing data more because of trouble and loss.
Avoid vibration
Vibration is one of the Acer Aspire 7720 Laptop Keyboard disk, the strong rivals will cause abnormal vibration and noise or disks even physical damage. Users should avoid in turbulence of using notebook on cars, ships, In the long and hard data on desktop notebook best smooth, Typing do gravity percussion; Avoiding extrusion hard disk area, such as single hand picked up the notebook, notebook placed in weight, etc. And, of course, is one of the advantages of the notebook, some vibrations moving office inevitably. So can purchase with shockproof advertent the hard disk or equipped with a shock
absorption cushion etc.
Avoid high temperature and other environments
Avoid long time (more than 12 hours) consecutive using notebook, Avoid to be put on a quilt, leg using notebook, lest blocked ventilation. Damp, strong magnetic field, the sunshine point-blank under the environment of the influence of using notebook hard is very big. Users should avoid to be in the bathroom, speakers subwoofer using notebook beside etc, if under the environment of inevitable, also can use in short time.
Avoid frequent reading data
Not long time continuous use notebook BT download, don't use the laptop do resources server. Using the Windows XP operating system user, strongly suggest adding to or greater memory 512MB to reduce the probability and hard disk. Use Windows Vista operating system user, strongly suggest adding to or greater 1GB memory to reduce the probability and hard disk.
Regular papers
System in use Acer Aspire 5630 Laptop Keyboard for a long time, after the hard disk will produce more file fragment, influence and accelerate data access speed drive aging. Users can best every two months, a disk around half system, but also do not want too frequently, to improve the speed of the system is Acer TravelMate 2350 Laptop Keyboard effective.
Computers & Internet Logo
i need the maitenance manual for your sdmo 500kva generators
Regular maintenance for generator is necessary that can help prolong the service life of the generator.
Generator Maintenance Tips
Generators
Generator Set Maintenance Tips
Useful Maintenance Tips for Diesel Generator Set
Maybe You Are Interested VOLVO generator Volvo Generator Volvo Generator Set Supplier Manufacturer Factory in China
Aug 30, 2011 | Computers & Internet
what is the regular maintenace when the car hits the a type service
regular maintenance is performing the changing of fluids or parts and checking systems for wear and proper operation at a interval set by the manufacturer (or dealer)in order to prevent premature wear or damaging internal parts by worn fluids or wearing parts therefore prolonging the life of the vehicle
Feb 07, 2011 | 2003 Mitsubishi Galant
jearking between shifts filter and fluid has never been changed 80000 miles
It sounds like you just need to service your transmission and request a transmission additive such as Trans X to be added to the transmission since there are high miles and low maintenance. This may help to prolong the life of your transmission.
Jul 23, 2010 | 2000 Pontiac Montana
rotor life
No, the stuff installed from the factory sometimes is junk. a good aftermarket set of rotors will prolong the life of them.
Jun 11, 2008 | 2004 Nissan Quest
145 people viewed this tip
David Payne
David Payne
