Tip & How-To about Computers & Internet
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
Computers & Internet Logo
set msi 171f to factory defaults
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
hope this helps
Jun 26, 2012 | MSI MS-171F (937-171F44-001) Barebone
I need a new Windows Vista for my computer.I have got computer with Windows XP but I would like to have Windows Vista. What I have to do ?
First changing computer opering systems is possible. A new Vista operating system has to be acquire from retails usually $200 value pack. Attempting the install new operating systems is achievable only may require expert to ascertian whether the old would have to be deleted to make way for new. usually inserting the new disk into disk drive should capture new effects. Unless any peculair encounters were experieced, the installation change is achievale. The reason to allow technicain to perform the changes is to gurantee againts any situations that may occur least repairable by computer neophyte. estimate the program changes of $200 to acquire new system program and technicains experts installation may have raised costs. Installations of systems are usually same rates $49. Several options available to acquriing computers that has XP systems. Recent computers are windows 7. However, the used devices computer retails may have functioning computers with XP systems. Also, simple, acquire another computer system unit that performs on windows XP to be pluged into the monitor screen to attain experinces. Whenever required, the computer sytem unit with XP is interchaged with the computer with Windows Vista. Ironicly, i have a computer with Vista and would also need to convert to XP though experiecing cost conditions. Consider exchanging computers with me.
Feb 09, 2011 | Microsoft Windows Vista Ultimate Edition
It is not a problem but a question. Can I install Outlook in windows 7 and will ntelos support it as my mailbox?
Yes, but you will need to make sure if the version of Outlook that you have is comaptible to windows 7.
Officially only Outlook 2003 and Outlook 2007 are supported to run on Windows 7. This is similar to Windows Vista which also did not support earlier versions of Outlook. You can install a version prior to Outlook 2003 on Windows 7 though but there are several issues which you could encounter.
In addition to these version requirements, even with Outlook 2003 and Outlook 2007 there are several compatibility issues which you could encounter on Windows 7. The most critical of these issues have been taken care off in prior service pack releases. So before starting Outlook on Windows 7, make sure your first apply at least Service Pack 3 for Office 2003 and Service Pack 2 for Office 2007.
Hope this will help...Your response is very much appreciated...
Jan 24, 2011 | Computers & Internet
can not open itunes
Some times a newly installed version of iTunes for Windows will not open. Even though it may still shows as running in the Windows Task Manager(Ctrl+Alt+Delete-click Task Manager).
Resolution:
1. From the Start menu, click Computer.
2. In the Organize menu, click Folder and Search Options.
3. Click the View tab.
4. In the "Advanced settings" pane under "Hidden files and folders" make sure that the "Show hidden files and folders" option is selected. And Click OK.
5. Navigate to the following location by either typing it into the address bar, copying and pasting it into the address bar, or clicking through the folder hierarchy listed: C:\Program Data\Apple Computer\iTunes\SC Info
6. Right-click the SC Info.sidb file shown and on the shortcut menu, click Delete
7. Right-click the SC Info.sidd file shown and on the shortcut menu, click Delete.
8. Restart the computer and open iTunes.
*HOPE IT IS FIXED*
Oct 22, 2010 | Microsoft Windows Vista Ultimate Edition
software
Your system has a hidden partition with Vista and all your drivers on it, you need to decide wether to keep this partition in tact (incase you want to install Vista again) or to delete it and use the whole drives available space making it one partition instead of two.
ONLY delete the recovery partition if you have a copy of windows XP that you OWN. otherwise if you have problems again, you will have to find a disk again.
You will need a copy of windows xp, set the bios to boot to the cd/dvd rom in the BIOS and boot the system with the xp disk, do a full install first delete any partitions (unless you save the hidden partition, then just delete the large partion)
Repartition the empty space , then format the drive, which you will be prompted to do after partitioning, then the cd will install windows. follow the prompts.
Once finished , go here http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
and download the 5 XP drivers for your system, install the chipset andcpu driver , then proceed to the NIC, audio and video.
You will then need to install any programs you had installed before. keep in mind a vista version of software may not operate correctly on XP. windows xp is about 130 dollars for the disk , but you can find copys on ebay for around 90.
poast again if you need more help
Regards..
Apr 06, 2009 | Acer Aspireā„¢ T180 PC Desktop
306 people viewed this tip
David Payne
David Payne
