Tip & How-To about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Pentair Intelliflo Pump Alarms and Continual re-Priming
Many pool owners seem to experience the situation with the Intelliflo Variable Flo (model numbers have changed over the past 3 years) pump alarming and re-priming continually and then stopping. I had this problem for nearly two years and spoke to the actual pump designer. We ultimately solved it as there was a spring valve in the heat pump I have. Any type of spring valve (or similar item) is a problem for the intelliflo as the pump is tooooo intelligent. When the spring opens and closes with water flow (or depending on what it was designed to do) it makes the pump think that there is a blockage and it reacts by shutting off and creating an alarm.
The solution is to replace the spring valves (or item that is varying the flow in the system) in your pool circuit. I was able to create a work around that used a manual valve just before the spring valve to reduce the flow so that the spring would not move and thus impact the pump. Basically you need to be ascertain if there are any parts in your pool flow that alter the water flow and thus pressure at any time (ie such as a spring valve) as the intelligence of the pump will take that to be an irregularity and shutdown. This can be time consuming and I hope this helps.
Note: you can test the pump to confirm that it is the intelligence that is causing the fault by putting the pump into FULL manual mode - consult the manual as merely pushing the manual switch does NOT disable the fault protection and system intelligence.
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
Power out Failure alarm
need more info will pump motor spin freely if not turn by hand remove cover on back of motor sometimes they lock up with power off turn by hand a few times then try with power
Mar 30, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair intelli flo vs+Svrs no display
see if voltage to switch and relay and to pump if voltage at pump bad controls or transformer
Jan 06, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
How do I manually reset my Intelliflo pump? The priming alarm came on after I tried to vacuum pool. Now it wont work.
turn off breaker to pump for a few minutes, then back on this will reset your alarm. If the problem returns ,check other posted solutions. In a few weeks i may have location of someone who repairs circuitboards for pentair pumps, as i am having one repaired now due to lightning hit.
Jul 22, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
1,125 people viewed this tip
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
