Tip & How-To about Cell Phones
Prolong the Life of Your Battery
  1. Initialize a new battery. New batteries should be fully charged before their first use to obtain maximum capacity. Nickel-based batteries should be charged for 16 hours initially and run through 2-4 full charge/full discharge cycles, while lithium ion batteries should be charged for about 5-6 hours. Ignore the phone telling you that the battery is full--this is normal but is not accurate if the battery is not initialized. #DO NOT fully discharge a lithium-ion battery! Unlike Ni-Cd batteries, lithium-ion batteries' life is shortened every time you fully discharge them. Instead, charge them when the battery meter shows one bar left. Lithium-ion batteries, like most rechargeable batteries have a set amount of chargers in them.
  2. Keep the battery cool. Put the battery in the freezer or fridge. Your battery will last longest if used near room temperature, and nothing wears on a battery like extended exposure to high temperatures. While you can’t control the weather, you can avoid leaving your phone in a hot car or in direct sunlight, and you don’t have to carry your phone in your pocket, where your body heat will raise its temperature. In addition, check the battery while it’s charging. If it seems excessively hot, your charger may be malfunctioning.
  3. Charge your battery correctly, in accordance with its type. Most newer cell phones have lithium-ion batteries, while older ones generally have nickel-based batteries. Read the label on the back of the battery or in the technical specifications in the manual to determine which yours is.
    • Nickel-based batteries (either NiCd or NiMH) DO NOT generally suffer from a misunderstood phenomenon known as the "memory effect." As described in Wikipedia and many expert sources, the term "memory effect" has been widely mythologized to describe any and all deterioration of NiCd (and other battery chemistries), in many cases misleading consumers into further shortening the lives of the batteries through over-discharging to "recondition" them.
    • This section formerly read: If you charge the battery partially enough times, eventually the battery "forgets" that it can charge fully. A nickel-based battery suffering from memory effect can be reconditioned, which requires the battery to be completely discharged, then completely recharged (sometimes several times). The appropriate length of time between reconditionings varies. A good rule to follow for nickel-battery cell-phones is to discharge them completely once every two to three weeks, and only when you have a charger available.
    • Lithium ion batteries can be preserved by careful charging and avoiding storing them at full charge.They do not require "reconditioning."
    • Regardless of the battery type, use only a charger rated for your battery, and discontinue use of a charger that causes the battery to heat up excessively.
  4. Store batteries properly. If your battery will be out of use for a while, disconnect it from the phone and store it in a cool place (the refrigerator is good, but freezing temperatures do not slow oxidation) and away from metal objects. Ensure that the battery is not exposed to moisture; try putting the battery in an airtight container or bag. Lithium ion batteries are not rated to operate at refrigerated temperatures, so let the battery sit outside the refrigerator for at least an hour before using it again. Lithium ion batteries oxidize least when they are stored at 40% charge. Never store a lithium battery at low voltage. Recharge batteries after storage.
  5. Clean the battery contacts on the battery and on the phone. Over time, contacts may accumulate dirt. Clean them with a cotton swab and rubbing alcohol to maximize the efficiency of energy transfer. In addition, if the contacts are two different metals, such as gold and tin, accelerated corrosion known as "galvanic or bi-metallic" occurs. Cutting the corrosion from the contacts often requires solvents, such as acetone or nail polish remover. Be careful: these solvent dissolve plastic, so use a Q-Tip to avoid damaging the battery housing or the phone.
  6. Use a black background whenever possible. AMOLED screens use a lot less power displaying black instead of white When web browsing use sites like bGoog.com that displays a black Google background instead of white.
Cell Phones Logo
aspire zg5 battery won't charge
Memory effect, also known as lazy battery effect or battery memory, is an effect observed in nickel cadmium rechargeable batteries that causes them to hold less charge. It describes one very specific situation in which certain NiCd batteries gradually lose their maximum energy capacity if they are repeatedly recharged after being only partially discharged. The battery appears to "remember" the smaller capacity.
This may be why.
Jul 29, 2009 | Acer Aspire One PC Notebook
Camera shows battery exhausted with new batteries.
You should be using Nickel metal Hydride batteries (NiMH). Do not use Nickel Cadmuim(NiCd), Zinc carbon or alkaline.
Mar 12, 2009 | Nikon Coolpix L1 Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
223 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
