Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
Unable to open .PPS attachments directly from Windows Mail in Windows Vista
To resolve the issue, follow these steps:
For .PPS files (Microsoft PowerPoint Slideshow)
· Click Start, type regedit.exe and press ENTER
· Navigate to the following branch:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.11\shell\Show
· Right-click Show and click Rename
· Type the word Open so that Show is replaced by Open command
· If you have PowerPoint Viewer 2007 installed, repeat the above steps in this key, as well:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.12\shell\Show
· After changing Show to Open, close Registry Editor window.
For .PPT files (Microsoft PowerPoint Presentation)
HKEY_CLASSES_ROOT\PowerPointViewer.Show.11\shell\Show
HKEY_CLASSES_ROOT\PowerPointViewer.Show.12\shell\Show
HP Pavilion a1410n (ER890AA) PC Desktop Logo
how do i fix ppt file? Please help
Hello. There are different methods available to recover corrupted PowerPoint files.
Open presentation in MS Word document
and follow this steps:
- Open MS Word.
- Click on Open button of File menu.
- Select Files of type box and navigate to your corrupt file, Open it.
Also you can try Recovery Toolbox for PowerPoint https://powerpoint.recoverytoolbox.com/
More information see here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/677-how-to-recover-powerpoint-file
Feb 05, 2015 | Microsoft PowerPoint for PC
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Powerpoint 2007 Hyperlink problem
Disable hyperlink warnings for 2007 Office programs loadTOCNode(2, 'moreinformation'); To disable the hyperlink warnings in 2007 Office Programs when an http:// address, notes:// or an ftp:// address is used, you must create a new registry subkey. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open dialog box, type regedit, and then click OK.
  3. In Registry Editor, locate one of the following registry subkeys:
    • HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Common
    • HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\12.0\Common
    NoteYou only have to modify one of these registry subkeys. You do not have to modify both of them.
    Note If the Security subkey already exists, skip to Step 6 after selecting the Security subkey.
  4. Click the registry subkey, point to New on the Edit menu, and then click Key.
  5. Type Security, and then press ENTER to name the key.
  6. On the Edit menu, point to New, and then click DWORD Value.
  7. Type DisableHyperlinkWarning, and then press ENTER to name the entry.
  8. In the right pane, right-click DisableHyperlinkWarning, and then click Modify.
  9. In the Edit DWORD Value dialog box, click Decimal, and then type 1 under Value data.
    Note A value of 0 enables the hyperlink warning message. A value of 1 disables the hyperlink warning message.
  10. Click OK.
  11. Exit Registry Editor.
uparrow.gifBack to the top If you still receive a warning message loadTOCNode(2, 'moreinformation'); You may still receive a warning message from Microsoft Windows. If you continue to receive a warning message after you follow the steps in this article, use one of the following methods to resolve the issue. Method 1: Turn off the "Confirm open after download" option for the file type that you are trying to open loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer.
  2. On the Tools menu, click Folder Options.
  3. On the File Types tab, select the appropriate file name extension (for example, WMV) in the Registered File Types box, and then click Advanced.
  4. Click to clear the Confirm open after download check box, and then click OK.
  5. In the Folder Options dialog box, click Close.
Method 2: Modify the HKEY_CLASSES_ROOT\WMVFile\EditFlags registry subkey loadTOCNode(3, 'moreinformation'); Use this method if the warning message affects multiple computers.
To disable the warning message, follow these steps:
  1. Click Start, click Run, type regedit, and then click OK.
  2. Locate the following registry subkey: HKEY_CLASSES_ROOT\WMVFile\EditFlags
  3. Click EditFlags, and then click Rename on the Edit menu.
  4. Type OldEditFlags, and then press ENTER.
  5. On the Edit menu, point to New, and then click DWORD value.
  6. Type EditFlags, and then press ENTER.
  7. On the Edit menu, click Modify.
  8. In the Edit DWORD Value dialog box, click Hexadecimal under Base.
  9. Type 10000, and then click OK.
To re-enable the warning message, follow these steps:
  3. Click EditFlags, and then click Modify on the Edit menu.
  4. Type 0, and then click OK.
Jun 18, 2009 | Microsoft Office PowerPoint Home and...
I use windows media player to open e-mail attachments ie: video,audio and pictures.Untill recently i would open the e-mail,click on the attachment,wait for the dialog box to open. I would click "open" and the attachment would play on windows media player. Now ihave to"save" the attachment then open it from "my documents/downloads. How can i restore the original click to open feature? Same problem with PPs files in windows Power Point and jpegs with windows picture and fax viewer. Any help is appreciated.
>i found this only for PPS file not opening from windows mail but open fine once we save it , try this only for power point files For .PPS files (Microsoft PowerPoint Slideshow)
  • Click Start, type regedit.exe and press ENTER
  • Navigate to the following branch:
HKEY_CLASSES_ROOTPowerPointViewer.SlideShow.11shellShow
  • Right-click Show and click Rename
  • Type the word Open so that Show is replaced by Open command
  • If you have PowerPoint Viewer 2007 installed, repeat the above steps in this key, as well:
HKEY_CLASSES_ROOTPowerPointViewer.SlideShow.12shellShow
  • After changing Show to Open, close Registry Editor window.
HKEY_CLASSES_ROOTPowerPointViewer.Show.11shellShow
HKEY_CLASSES_ROOTPowerPointViewer.Show.12shellShow
Screenshot ppsopen_vista.gif (Fig 1) Show is renamed as Open
Jan 24, 2009 | Microsoft Windows Media Player
Unable to open .pps attachments from windows mail in windowsvista
If you have Windows XP:
Manual fix
  • Click Start, Run and type CONTROL FOLDERS
  • In the Folder Options applet that opens, select the File Types tab
  • Scroll down and locate the following entry:
PPS (Microsoft PowerPoint Slide Show)
  • Click Advanced
  • Click the New button
  • Type Open in the the Action: text box
  • In the Application used to perform action: field, type the following exactly:
For PowerPoint Viewer 2003:
"C:\Program Files\Microsoft Office\PowerPoint Viewer\pptview.exe" "%1"
For PowerPoint Viewer 2007:
"C:\Program Files\Microsoft Office\Office12\pptview.exe" "%1"
  • Uncheck the Use DDE box
  • Click OK, OK
  • Close the Folder Options dialog
-Tha Mp3 Doctor
Dec 31, 2008 | Microsoft Windows Vista Home Premium with...
2,646 people viewed this tip
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
