Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
Instructions for Setting AutoAdminLogon
Launch Regedit. (See more details on starting regedit)
Navigate to:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\winlogon
Set: AutoAdminLogon = 1 (one means on, zero means off)
Tip: Try Regedit's 'Find': AutoAdminLogon
Create a new String Value called DefaultPassword
Set: DefaultPassword = "P@ssw0rd"
Check for the existence of a REG_SZ called DefaultUserName. The value should reflect the user who you wish to logon automatically. If this value does not exist, then right-click in the right pane, New, REG_SZ, name it, DefaultUserName. Set the string value to the required UserName.
Optional Item: If your Vista Machine has joined a domain, then create a String Value called DefaultDomainName.
Set: DefaultDomainName = "OnlyYouKnowDomain"
HP Pavilion a1410n (ER890AA) PC Desktop Logo
windows script host
My Documents Folder - Opens Upon Boot
To Stop Windows Explorer from opening My Documents: Check your settings here: Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
In the right pane under Userinit - Change the key that reads:
C:\Windows\System32\Userinit.exe,C:\Windows\System32\Userinit.exe
To:
And also here: Start/Run/Regedit
Start/Run/Regedit
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows. In the right pane, check your settings under Load.
try this rate the solution
Jul 06, 2009 | Computers & Internet
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
windowx xp booting time no icons appear.
Changing the default shell (all users):
1) open regedit (start menu > run, and type in regedit)
2) go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) Change Shell from explorer.exe to the new shell path e.g C:\Litestep\litestep.exe
4) log out and log back in.
Changing the default shell (only current user):
1) open regedit (start menu > run, and type in regedit).
2) go to: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) add a new string value (Edit > New > String Value) called shell. and set the value to the path of the new shell e.g C:\Litestep\litestep.exe.
http://support.microsoft.com/kb/228309
May 09, 2009 | Computers & Internet
how to disable start menu from desktop
tell me exactly what you want to use this for.
Is it for a internet cafe? I will then be able to give you the best solution.
Using group policy you can take out options within the start menu but cannot remove it totally.
If you want your computer to only start up internet explorer as soon as you turn the computer on, then you will need to play around with the system registry to do that, in order to disable explorer from lunching.
Go to Start/Run/Regedit and navigate to this key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Download readystate from microsoft and play around with that, a very cool tool.
Jun 26, 2008 | Compaq Presario 5000 PC Desktop
2,017 people viewed this tip
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
