Tip & How-To about HP Pavilion a1410n (ER890AA) PC Desktop
Virtual memory settings
Windows XP
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab. In the Performance section, click Settings.
3. Click the Advanced tab. In the Virtual memory section, click Change.
4. The hard disk drive that is used for virtual memory will usually be the
5. same disk drive that Windows is installed on. Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be approximately 200 MB in size but should be higher than or equal to the recommended paging file size as indicated in the lower section of the screen.
Once the initial size is set, Windows will reserve this amount of space on the hard disk drive for virtual memory and it will not be available to save information on.
The maximum amount allowable can be anything above the Initial size setting, but it is recommended that it be at least twice the Initial size setting
HP Pavilion a1410n (ER890AA) PC Desktop Logo
WAIT AGES FOR THE COMPUTER TO START UP EVEN LONGER FOR WEB PAGES TO COME UP. DO I NEED TO RESTORE FACTORY SETTINGS
Try the following steps to speed up your computer.
1) Try running Windows Disk Defragmenter from Start>Programs>Accessories>System Tools. Wait it to complete.
2) Then delete temporary Internet files by doing this. Start>Run> %temp% > Ok. Delete all the files which will be shown.
3) Go to My Computer and select the drive in which windows is installed. Make sure you have atleast 1 GB free space in it.
4) Right click on My computer Icon on your desktop & go to Properties. Go to Advanced tab. In Performance section click on Settings. In the Performance Options select the Advanced tab and in the virtual Memory section check the Page file size, it should be atleast 1 GB. If not increase it.
Restart your system.
Hope this helps. Good luck.
~SmokinJoe~
May 24, 2011 | Computers & Internet
i have a emachine e627 i got it in Dec of 2009 and a blue screen flashes up that says driver_trol_not_less_or_equal_ than windows try to restart again..
3. Under Performance, click Settings.
4. Click the Advanced tab.
5. Under Virtual Memory, click Change.
6. Click No paging file. Click OK, click OK, and then click OK.
7. Restart your computer.
8. Click Start, right-click My Computer, and then click Properties.
9. Click the Advanced tab.
10. Under Performance, click Settings.
11. Click the Advanced tab.
12. Under Virtual Memory, click Change.
13. Click System managed sized. Click OK, click OK, and then click OK.
14. Restart your computer.
Hope this works!
Jun 12, 2010 | Computers & Internet
virtual memory
yes upgrading your ram (random access memory) helps alot
also incressing your virtual memory paging file might work if it is set 2 low.
Windows XP loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Advanced tab. 3. In the Performance pane, click Settings. 4. In the Performance Options dialog box, click the Advanced tab. 5. In the Virtual memory pane, click Change. 6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK. 7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
Dec 07, 2007 | Acer Aspire 3000 Notebook
2,106 people viewed this tip
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
