Tip & How-To about Cell Phones
How to set ringtone when unable to set in Nokia 1200,1202,1203etc.
This trick is very easy but we could not discover.Here follow the instruction step by step First power on the phone, press menu and select setting in sub-menus. Then press "RESTORE FACTORY" reset it by entering 12345 (default code) or the code you have already modified!!!!!!!! ha....ha.........Before restore factory you have seen that there was no tone displayed in ring tone setting sub-menu besides when you try to set the ring-tone suddenly the phone shut down and automatically power on itself.....No tension no upset entertain the lovely NOKIA tone.........
Cell Phones Logo
How to get my pass code back on my ipad
I assume you mean the code for the headset?
The default is "0000" when pairing.
1.
Ensure the headset is off (see Turning headset on/off section).
2. Press and hold Power until you see a solid blue light (approximately 8
seconds), then release* (see Fig. 3).
3. Set your Bluetooth phone to "discover" the headset by following your phone's
instruction guide. Typically, the steps involve going to a "setup", "connect", or
"Bluetooth" menu on your phone and then selecting the option to "discover" a
Bluetooth device.
4. Your phone will find the "Samsung WEP170" headset and ask if you want to pair with
it. Confirm this by pressing "yes" or "ok".
5. Enter passkey or PIN4 = 0000 (4 zeros), then press "yes" or "ok".
Manual link
http://downloadcenter.samsung.com/content/UM/200906/20090609223230593/WEP170_ug.pdf
Jun 07, 2014 | Samsung WEP170 Wireless Headset
After about 10 seconds the receiver turns off. I have discovered a trick to make it stay on. If I play a CD for a few seconds then switch to cable/sat, the system will stay on. I am not always able to make this trick work. Also, now all DVDs are playing in black and white. Thanks
1.Check that both power cables are securely connected to the media center and the speakers and that they are connected to working outlets.Try unplugging the media center for several seconds, then plugging it back in to restart the system.
2.Restore the Bose System to factory settings :
Follow these steps: >On the remote, press System. Be sure the correct TV input is selected
>Press the Right arrow to highlight the "Media Center" icon and press ENTER Press the Down arrow to highlight "Restore Settings" and press ENTER
>Press the Up arrow to highlight "Yes" and press ENTER. The display asks: "Have you been instructed to do this?"
>Press the Left arrow to select "Yes" and press ENTER >Press Exit to leave the menu.
Sep 05, 2011 | Bose Lifestyle 48 System
How do I set the date and time on my new Samsung Genoa?
samsung make it easy for us to set our phone to our liking. :) if you want to set the date and time on your samsung, do the following steps..
1. press menu 2. select settings 3. select date and time and slide your hand up to select for the options and set your phone.
option 2, if you the date and time settings are not there consider this steps.. 1. press menu 2. select settings 3. select general 4. select date and time 5. slide your hand up and down for options and configure your phone.
goodluck..
Jul 10, 2010 | Cell Phones
My phone is set in Italian. How do I change the
My phone is set in Italian. How do I change the language to English?
Jul 06, 2009 | Cell Phones
I need to reprogram my Jabra BT125 to a new phone, but don't have the instuctions to do that.
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
1. Put the headset in pairing mode
• Make sure the headset is off .
Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or
‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful
pairing, repeat steps 1 to 3.
Jul 12, 2008 | Cell Phones
883 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
