Tip & How-To about Apple iPhone 3G
How to restore a troublesome iPhone 3G!
If you have an iPhone 3G that is causing you problems or errors when you are trying to restore then hopefully this information can be useful to you.
If you are struggling to get your computer or iTunes to recognize your iPhone then put the device into recovery mode. To put the device into recovery mode, plug the iPhone into your computer, open iTunes, then hold the sleep button and the home button together for ten seconds before releasing the sleep button. Contine to hold the home button until iTunes pops up and tells you that a device has been detected that needs restoring.
Click restore and iTunes will download and restore the latest firmware to your device for you. Once the restore completes you can set up a new phone or restore al settings from a backup of a previous phone.
If after restoring you get an error message and your iPhone displays a plug into computer logo then we must go through some more steps to get your iPhone going.
This section is for users of 32 bit Windows, which is the majority of people. Download the iRecovery and libusb-32 package and install the libusb-32 file. Move the irecovery.exe file to C:irecoveryirecovery.exe
From your start menu go to Run and type cmd. Press enter and you will be presented with a black box with a command prompt. At the command prompt type C:irecoveryirecovery.exe -s and press enter.
Once your iPhone has been found you will have another command prompt. Now type the following commands:
setenv auto-boot true
saveenv
exit
Once again reboot your iPhone, holding sleep button and power button until the Apple logo displays, this time your phone should boot up into the normal iPhone interface.
With a bit of luck you have just restored your iPhone 3G!
Apple iPhone 3G Logo
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
help on frozen iphone 3.1.3...want to restore
just switch off your phone and press home button and connect to cable and restore it from there it would get solved
May 25, 2010 | Apple iPhone 3G
freezed updating
the iphone 3g has alot of problems internally... you should keep the old version....
Nov 22, 2009 | Apple iPhone 3G
My iPhone 3G suddenly stopped working. The screen
In certain situations, an iPhone will automatically go into recovery mode after an update or restore issue. If your device is already in recovery mode, you can attempt to restore using iTunes.
Please follow steps on this link http://support.apple.com/kb/HT1414
Note: Restoring your device will delete all the data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Nov 20, 2009 | Apple iPhone 3G
1,327 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
