Tip & How-To about One For All URC-7800 Remote Control
Programing your remote controller
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-vcr.shtml#dvd
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash radidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programing your remote can be found here: http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
One For All URC-7800 Remote Control Logo
Code
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
More help for programming your remote can be found here:
Hope that helps! If that didn’t work, you will probably have to contact the manufacturer to get the code..
Thank you for using FIXYA!
Cheers!
IrishDruid
Jun 21, 2008 | GPS
no one for all remote code for lg tv dvd combi
Cheers!
IrishDruid
May 28, 2008 | Televison & Video
no code for lg tv dvd combi
Cheers!
IrishDruid
LG DVD remote control
Cheers!
IrishDruid
May 28, 2008 | LG DR-4810 DVD Recorder
2,798 people viewed this tip
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
