Tip & How-To about Video Game Consoles & Games
How to posible fix the error e68 on xbox360
Cheac for dust on the hard drive it mig be the problem.
HOPE THEIS HELP :) | (:
S W R
M A E
I T F
L H L
Y E C
! R T
! ! I
! ! O
! ! N
Video Game Consoles & Games Logo
Regonises the USB attatched to the hard drive but not the hard drive itself?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 06, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
do I need a pwer cord for theis model or will it
Look at the connectors on the outside of the case.
If there is a socket for an AC adapter, then it requires one.
If there is no such socket, then none is required.
Jul 31, 2010 | SmartDisk FireLite 60 GB Hard Drive
i have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
Jan 05, 2010 | Hobart Handler 140 Mig Welder
My iomega portable hard drive fell off the table onto the floor and now it does not work it makes a funny high pitched beeping noise and does not sound like the drive disks are moving. What should i do?and where could i send it to get fixed?
I don't know this hard drive to well but I know that when a hard drive is dropped/fallen onto the floor, it probably won't work seeing as they are fragile. You'll have to phone the company that created/imported this drive because they'll have the spare parts to fix it.
Dec 07, 2009 | Computers & Internet
Mig welder
Sometimes dirt builds up at the beginning of the liner, at the drive. Eventually the dirt jams in there so much that it gets very hard to push the wire through it. Carefully cut the wire between the spool and the drive and secure it to the spool through a hole, so it doesn't unspool into a bird nest, then disengage the drive roller, the wire should pull out of the tip freely. If you feel resistance when you pull it out, either there is dirt at the beginning of the liner, or the contact tip is causing resistance. Without the wire in the drive, turn on the machine and try it watching the drive. Does the drive work freely now? Does it change speed with the rheostat? If its a problem with dirt, this is what I do, after you get the wire threaded back through the drive, liner and contact tip, and everything is working, take a small clean cotton rag and simply tie it around the migwire between the spool and the drive, in a way that the drive can't **** it in. This will constantly clean any dust/dirt off the wire before it goes through your expensive drive and liner. Whenever you change the spool, change the rag. Hope this helps, and please post your results.
Jan 31, 2009 | Welding Tools
607 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
