Tip & How-To about Computers & Internet
Prevent a virus attack no your computer through USB pen drive or Hard drive
There are lots of viruses available that gets distributed with the help of USB per drives or portable hard drives.
So here is a useful tip which can be kept handy to prevent them from infecting your System.
Do not double click to open a removable drive or the portable hard drive or pen drive. Always right click and select explore from my computer. This is because, the virus would have created Autorun scripts that will get executed when double clicked. The scripts infects your computer with the same virus.
Once the removable drive is opened by selecting explorer, Navigate to Tools > Folder Options > Views. Find the radio button to show hidden files and folders. and also uncheck the option "Hide extensions for known file types"
Now of you find some new unknown files in your removable disk, try deleting them permanently by pressing shift+DEL. If it fails, copy required files from your device and then format the drive.
Hopes this tip helps someone.
Computers & Internet Logo
it want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
need the driver to set it up - have an eGo -Want to set up automatic backup
Drivers for this hard drive can be located here. Select the operating system you are using to get the correct version of the driver.
May 06, 2011 | Iomega eGo160GB External USB 2.0 Portable...
My simpletech 60GB storage device does not show up in my list of available drives when connected. The storage device blinks for a few moments when connected but then the light goes out. I can feel the vibration of the device when it's connected; making me think it's working. But it never shows up in my list of available drives. I must be able to access the info I have stored on it. Please help.
A lot of NEWER SimpleTech drives have some new technology called NDAS (NetDisk Attached StoragE), which eliminates the need for IP addresses on a network. Its highly secure and very hard to find, unless you have the software available for it.
Download these drivers and you should be able to get to your stuff. Good luck and have a great day!
Jun 22, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
HOW DO I USE THE PORTABLE HARD DRIVE?
Does this 'portable hard drive" have a USB connector? Simply plug the drive into an available USB port. Open up the Computer icon on your computer, and look for a new drive letter. That will be your Portable drive, and you can use it for backups and file storage as any other drive.
Dec 15, 2009 | Computers & Internet
255 people viewed this tip
David Payne
David Payne
