Tip & How-To about Cell Phones
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
Cell Phones Logo
cannot delete call logs in nokia c3
Good day. Go to phone menu, and select phone book. Browse and select log, all the information from your recent calls and text, even call duration you can find it there. There is a manual delete procedure that you can choose. Thanks
Sep 10, 2011 | Nokia C3 Cell Phone
my phones screen is broken, however the phone still works so i've been trying to connect to my pc in order to transfer my files, but i'm unable to navigate the menu in order to get it onto the correct settings! Are there picture by picture instruction availabe?
go to Nokia site and download the manual , or if you have your own manual , write down the numbers of each button neede to press. Then press menu and the numbers in sequence , and this will get you into pc mode [data]. You can try...menu * 7 2 [then press main ok button twice [ok ,ok] ] Hope it works!
Sep 14, 2009 | Nokia 6210 Navigator Cell Phone
N81 8gb,keypad lock switch not working
check kep pad connector
or - chnga ic
Mar 26, 2009 | Nokia N81 Smartphone
406 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
