Tip & How-To about Cell Phones
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and classic Nokia Menu
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Save Contacts to SIM blind. Nokia Broken Screen
Press Central Navigation Button to get Menu
Press Up once - Contact Menu
Press Central Nav Button
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Press Button above call end several times to exit from the menu
Cell Phones Logo
cannot delete call logs in nokia c3
Good day. Go to phone menu, and select phone book. Browse and select log, all the information from your recent calls and text, even call duration you can find it there. There is a manual delete procedure that you can choose. Thanks
Sep 10, 2011 | Nokia C3 Cell Phone
my phones screen is broken, however the phone still works so i've been trying to connect to my pc in order to transfer my files, but i'm unable to navigate the menu in order to get it onto the correct settings! Are there picture by picture instruction availabe?
go to Nokia site and download the manual , or if you have your own manual , write down the numbers of each button neede to press. Then press menu and the numbers in sequence , and this will get you into pc mode [data]. You can try...menu * 7 2 [then press main ok button twice [ok ,ok] ] Hope it works!
Sep 14, 2009 | Nokia 6210 Navigator Cell Phone
N81 8gb,keypad lock switch not working
check kep pad connector
or - chnga ic
Mar 26, 2009 | Nokia N81 Smartphone
2,261 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
