Tip & How-To about Televison & Video
Changing power supply caps
When replacing bulging power supply caps,I prefer to use higher quality low ESR caps rather than radio shack parts and always (when space permits) go up to the next higher voltage. The low ESR caps last longer because the don't heat up as much. They can be purchased at Mouser or other major parts suppliers. I have a surplus dealer nearby that has them.
Phil
Televison & Video Logo
On / off indicater light keeps flashing red/green and tv will not power on lg du-37lz30
Common problems for most LCD and Plasma tvs sets.The tv power supply board it is the causes and problems,that the board where the tv a/c power cord plug into it.Take the tv aparts and check tv power supply board carefully looking for dying an leaking components capacitors parts.These dying and leaking capacitors parts are alway bulges up onto it tops or puffing up onto it tops.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes.All these dying and leaking components capacitors parts are bulges up or puffng up onto it tops u must have to replace them.Replaces all these dying and leaking capacitors components parts with the same Miro Farad but upgraded all those capacitors parts voltages higher voltages like 5 or 10 voltages higher than those old capacitors components parts u are replacing.By replacing all those old dying and leakages capacitors parts voltages higher 5 or 10 voltages higher.The capacitors parts will with stand heat better than those old capacitors parts was in the power supply board earlier.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 23, 2011 | LG DU-37LZ30 37 in. LCD HDTV
My LG26CL2D power supply now make a squerling noise after I replaced 3 ea. bad cap. Any advice on this one.
Correct polarity and you use low ESR type not generic electrolytics from RADIO SHACK? Low ESR is a must for switching power supply. Also bad cap can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/?action=view&current=DSCF0262.jpg
Should also recheck your soldering work just in case.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | LG 26LC2D 26 in. LCD Television
The power on/off mechanism does not work (on box or remote) properly. Started with having to press button many times -- green light goes on 2 sec then goes back to red -- before the screen would come on. Now the green just flashes but screen never comes on.
U have all the tools and understanding basic electronic also can do soldering work?Take the tv aparts.Tv have power supply board problems issues.That the board where the power a/c cord plug into it.Check the power supply board carefully for dying components parts call capactors parts.These dying capacitors parts are alway bulges up or puffing up on to it tops,these capacitors must be replace like with the same micro ferid capacitors and votages higher 5 or 10 voltages for better heat resistance not to dying to soon again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 07, 2011 | Coby TF-TV1913 LCD TV
E176FPb REPLACED C703 AND C704 STILL FAILS DISPLAY AFTER 3 SECONDS POWER LIGHT REMAINS ON
You need to find out if you do have 12vdc and 5vdc for the inverter circuits and logic board, I usually repalce the caps in a set not just the bulging one since bad cap can look normal but has high ESR, you need to use low ESR type cap in switching power supply, generic Radio Shack will not work or last very long. I use Panasonic FM/FC series for all my repair works because it has low ESR, 105c and high ripple current and high rated life.
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Please post back what you find.
Nov 10, 2010 | Dell E176FP 17" LCD Monitor
270 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
