Tip & How-To about Washing Machines
Ddo mean
Soap dispencer open... or on side of soap dispencer have small magnet not on positionor misplace
Washing Machines Logo
Magnet came out and now washer won't run
on the under side of the dispencer, remove it, flip it over, fit it in with some glue, as far toward the inner part as possible, put it back, try the washer, if it still doesnt fill, try pulling it out a little and see if that works, if it does this is the amount you need to move the magnet back.
Feb 10, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Front Loader Washer will not turn on at all???
it came from your dispencer ..it activates a sensor on the unit right side,,,,take your dispencer out turn it over and that magnet goes on the left side when dispencer is right side up....yes that magnet is neeeded to start unit...onthejob
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
water filling issue with mty kenmore 417.44052400
Yes on the dispenser door there is a magnetic switch that looks like a thin black cylinder similar to a short pen . About 1 1/12 long. It may have been dislodged. Make sure the dispenser door is closing all the way.
Aug 17, 2008 | Kenmore 44042 Front Load Washer
washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
271 people viewed this tip
Top Washing Machines Experts
