Tip & How-To about Nokia N70 Cellular Phone
Nokia_Mobile_Secret_Codes
*#06# IMEI
*#0000# view Software Version
*#746025625# [*#sim0clock#]
*#92702689# [*#war0anty#] secret menu:
1. Displays Serial Number
2. Displays the Month and Year of Manufacture (0997)
3. Displays (if there) the date where the phone was purchased
4. Displays the date of last repairment - if found (0000)
5. Makes you capebel of transferring user data
6. Shows how many hours the phone has been on
*3370# Enhanced Full Rate Codec (EFR) activation
#3370# Enhanced Full Rate Codec (EFR) deactivation
*4370# Half Rate Codec activation
#4370# Half Rate Codec deactivation
xx# - xx position in Phone Book
NOKIA 9000
*#06# IMEI
*#682371158412125# soft version
*#3283# prod. date
NOKIA 7650
*#7979# phone reset
*#7470# hard reset
*#7370# master reset (like new phone)
Nokia N70 Cellular Phone Logo
how to get security code of asaha 303
Dial using the keypad: * # 0000 # - the version number displayed on the display.
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
*#7328748263373738# resets security code.
Default security code is 12345
SIM Clock
Stop allowed
Warranty Codes
* # 92702689 # [* # war0anty #]
Dec 29, 2014 | Cell Phones
nokia new models secret codes
View the firmware version of the phone
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
SimClock
SIM Clock
Stop allowed
Warranty Codes
Enter the menu of warranty codes. In fact, you do not need, but you can find them using the arrows scroll menu.
Menu:
1. Shows the serial number of the device.
2. Date and year of manufacture (eg 0299).
3. Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4. Date of last repair (if any)
5. Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
EFR CODEC (Enhanced Full Rate)
This function with its inclusion on the idea, should significantly improve the quality of speech, but unfortunately, it must be supported by your connection. When the work is slightly increased power in the phone call (about 5%). How do I know, none of the Russian cellular operators do not support this feature. Principle is based on a different compression algorithm for speech recognition (ACELP) and has a wider bandwidth.
Feb 28, 2011 | Nokia E71 Smartphone
all code sent my email
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
SimClock
SIM Clock
Stop allowed
Warranty Codes
Menu:
1.Shows the serial number of the device.
2.Date and year of manufacture (eg 0299).
3.Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4.Date of last repair (if any)
5.Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
Dial * 3370 # to activate (the phone should reboot) or # 3370 # to deactivate this function.
HR CODEC (Half Rate)
Substantially impairs the quality of speech, but saves battery somewhere at 30%. Again, must be supported by a mobile operator. American networks that support this feature, I do not know.
Dial * 4720 # to activate (the phone should reboot)
or # 4720 # to deactivate this function.
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Nokia 5230 Cell Phone
please help.,.,i need my license key.,., imie 35227201819836.,., thanks
insert code :
and
like this example :
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
i hope this helpful
Feb 07, 2011 | Nokia 6600
code locking of siemens mobile phone
Siemens Mobile Secret Codes:
C25:
SP unlock *#0003*(secret code 8 digits)#
*#0606# shows you Secret Code, but only without SIM Card.
*#06# for checking the IMEI (International Mobile Equipment Identity)
How to change PIN:
**04*old PIN*new PIN*new PIN#
How to check simlock status
*#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
S4:
Monitor Mode - how to activate:
Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
How to see date of software:
Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) >abck to "normal" and then left soft-key, 56.
S6, S8:
If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
S10, E10:
In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
S15e:
Monitor Mode:
Code: *#7436267*8378# (*#SIEMENS*TEST#)
Hold red phone button until it code disapears.
Menu 3.3.4 Choose frequency.
Menu 3.3.4.1 Automaticaly.
Menu 3.3.4.2 Choose GSM-900
Menu 3.3.4.3 Choose GSM-1800
Menu 10.1 MS info
Menu 10.2 Soft date
Menu 10.2.1 Software version.
Menu 10.2.2 EEProm version.
Menu 10.3 Tst and product info.
Menu 10.3.1 Handware data.
Menu 10.3.2 Date of manufacture
Menu 10.3.3 Service date
Menu 10.3.4 Date of repair.
S25:
Enhanced Full Rate
*#3370# turns on
#3370# turns off
Haft Rate Mode
*#4720# turns on
#4720# turns off.
Languages:
*#0000#+green phone - choose automaticaly
*#0001#+green phone - English
*#0030#+green phone - Greek
*#0031#+green phone - Netherlands
*#0032#+green phone - French
*#0034#+green phone - Spanish
*#0039#+green phone - Italian
*#0049#+green phone - German
*#0090#+green phone - Turkish
How to change PIN2?
**04*old PIN2*new PIN2*new PIN2#
What is my software version?
Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
How to extend battery life:
IrDA - turn on only when you need.
Turn off automatic network search (6-3)Turn off Vibration alarm.
Resets language to automatic selection : * # 0000 # then Green button
S25, M35, S35, C35
Nov 29, 2007 | Nokia 1100
2,317 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
