Tip & How-To about Computers & Internet
How to fix blue screen error
Sometimes depending on how far it will boot and what version of windows it is. You can hit the F8 key as it is first starting up and get into safe mode. From there you can get into "My Computer" and right click on the "c" select the tools tab and do a defrag and schedule a disk check - check both boxes in disk check - one says "check for errors" the other one say "attempt to repair" This might fix it about 60% of the time.
Sometimes it is caused by the device driver errors.
More information you can check:http://www.driverdownload4u.com/
Hope it helps.
Computers & Internet Logo
How to put toshiba f20 into safe mode
when the computer first starts to boot up tap the f8 key this should bring up the options for booting into safe mode if not try f5.
May 02, 2011 | Computers & Internet
display is blue
memory bad or try repair your os. is it xp/ 2000/ 98 ?
Jun 15, 2009 | Computers & Internet
the whole screen just turned blue and you cant see anything when it gets hilighted?
Sometimes depending on how far it will boot and what version of windows it is. You can hit the F8 key as it is first starting up and get into safe mode. From there you can get into "My Computer" and right click on the "c" select the tools tab and do a defrag and schedule a disk check - check both boxes in disk check - one says "check for errors" the other one say "attempt to repair" This will fix it about 60% of the time!!! Good Luck!!!!
Nov 27, 2008 | Computers & Internet
safe mode set up in sony laotop
When powering up from a cold start press F8 as if tapping on a piano. You may get a boot from what screen first, in this case press Escape and then F8 immediately thereafter. You should then see a Safe Mode Selection boot screen. Options include, Last Known good configuration. Often this is a good choice. Sometimes you are presented with a selection of Restore Points to choose from as well. These all depend on the Bios you have and what version of that bios is installed.
Do the F8 tap tap until you get the Safe Mode boot screen. When you do choose Safe Mode, you are then asked what OS to boot, usually this is only the version of XP or Vista you have onboard. In any case take that and press Enter again.
Don't dismay should you not get the F8 key press right the first time, there is a certain knack to it.
Regards,
Worldvet
Oct 16, 2008 | Computers & Internet
205 people viewed this tip
David Payne
David Payne
