Tip & How-To about Sport & Outdoor - Others
How to chage the belt on anny arctic cat snowmobile with diamond drive
To change a belt on a arctic cat snowmobile with diamond drive. your owner's manual will tell you to use a tool to let the clutch faces separate and so on. there is a much eyeser solution. there is a signal alen key bolt that holds the clutch to the diamond drive assembly. put this alen key in your tool kit and when ever you need to change the belt just undo this bolt remove the cluch from the diamond drive place belt on cluch and with minimal force replace the clutch on the shaft on the diamond drive then tighten the bolt.
Sport & Outdoor - Others Logo
arctic cat zr900
Open your chain case. Youll probably find your chain laying in the bottom.
Mar 03, 2014 | Arctic Cat 2008 CrossFire 8
2011 1100 cc Arctic Cat that stalls when coming to a stop. Doesn't do it all the times. Then starts right back up. Also backfires once in a while when you let the gas off.
The back fireing is common,but check the bushings in your drive clutch,when the inner goes bad,the clutch will not totally disingauge causing the sled to stall.
Mar 03, 2014 | Arctic Cat Winter Sports
need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
2,340 people viewed this tip
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
