Tip & How-To about Sony Playstation 3 (PS3) Console
ULTIMATE PS3 REPAIR GUIDE
Hello if you have found this tip then you must be looking to fix your PS3 console. The Solutions on this Tip work for all PS3 Consoles.
You now no longer need to search the internet for your PS3 problems they have all been gathered here in one place, I suggest you bookmark this page so you can use it when ever you have the need.
PS3 PROBLEMS - TOP 3 PS3 REPAIR GUIDES
http://www.fixya.com/support/r5263303-ps3_problems_top_3_ps3_repair_guides
THE RESET TRICK
http://www.fixya.com/support/r5095466-ps3_problems_reset_trick
FIX THE NO DISPLAY ERROR
http://www.fixya.com/support/r5072938-no_display_fix
FIX THE DISK READ ERROR
http://www.fixya.com/support/r5072803-disk_read_error_fix
FIX THE RED FLASHING LIGHTS ERROR
http://www.fixya.com/support/r5072723-red_flashing_lights_fix
FIX THE YLOD (YELLOW LIGHT OF DEATH)
http://www.fixya.com/support/r5072625-yellow_light_death_fix
PS3 PROBLEMS
http://www.fixya.com/support/r5036700-problems_ps3
I AM QUITE CONFIDENT TO SAY THAT YOU WILL BE BACK GAMING WITHIN 1 DAY OF READING THESE TIPS AND SOLUTIONS.
PLEASE HELP OTHER GAMERS AND RATE THIS TIP BELOW
Sony Playstation 3 (PS3) Console Logo
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
my PS3 turns on then off
sounds like a hardware malfunction
I have 2 solutions
1. You can repair your self with a good repair guide have a look at this Fix ya TIP
2. Send the console off to sony for a repair, usually free if still in warranty if not then its around $150
Do either of the 2 and you will get back gaming.
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not read games but will read dvd movies, help! thanks so much in advance if anyone can fix this!
This is quite a common problem on the PS3 unfortunately. The problem is caused by the laser lens on the disc drive. For a full breakdown of the causes and solutions please see this FixYa Tip.
Thanks for using FixYa.
Feb 01, 2010 | Sony Playstation 3 (PS3) Console
698 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
