Tip & How-To about Cycling
If you have created a website that is powered by googles blogger interface and
If you have created a website that is powered by googles blogger interface and you have moved it from the blogspot domain to a custom domain you might want to remove the blogger favicon from the search tab.
Here are several tutorials showing the easiest way to do it.
First you might want to backup your existing template either do this using the export or copy and paste it to notepad, this also gives you a great way of searching the template for the correct place to add the new HTML.
HOST FAVICON ONLINE: Upload favicon to an external web host, such as your Picasa album (which is automatically created for you when you upload pictures to your Blogspot).
If you've uploaded your favicon to Picasa, then click on the uploaded image. Click on "Link to this photo" (currently on the right side of the screen). Under "Embed Image", check "Image Only (no link"). Copy the embedded image URL. This is the location (URL) of your favicon.
ADD FAVICON TO BLOGGER: Visit your Blogger dashboard or Blogspot account. Click on "Layout", then "Edit HTML". You should now be presented with a screen allowing you to edit the HTML of your blog template.
Within the HTML, near the top, you should see:
[title][data:blog.pageTitle/][/title]
Immediately beneath that line of code, paste the following:
Replace the asterisk (*) with the following:
link rel="nofollow" href='*' rel='shortcut icon' type='image/x-icon'/
Replace this asterisk (*) with the URL for your favicon image.
SAVE YOUR TEMPLATE & TEST: Save your Blogger template, then click on "View Blog". If the favicon does not appear in your address bar, then try refreshing your browser. If you still do not see it, clear your browser's cache file and restart the browser. Renavigate to your blog.
Favicon Creator: Free from HTML Kit
Secondly you CAN host the favicon to a hosting website that will allow favicons, NOTE: neither of the main sites PenguinPic, Photobucket nor Imageshack do this one of the easiest ways to host it and get the HTML code is to use
http://www.iconj.com
They have an simple to use upload service that will generate the HTML code that you need to add to your blogger template
Finally you need to copy and paste the code that the website generated to the blogger template. The best place to add the code is directly after the code shown belows if you are using firefox you can use the CRTL + F to search it when found it will be highlighted green
or use the notepad copy and paste the entire code and search as normal
then paste the code surrounded by the comments that will allow you to find it more easily
EXAMPLE
When you save the template you will see that the favicon has changed from the default blogger for the one you created.
If you are using the old Blogger template instead of the New Blogger xml template,and paste the favicon codes immediately after this line of code:
<$BlogMetaData$>
If you are using your own Webserver
Is another cool site that will allow you to resize and create your favicon.jpg is http://www.genfavicon.com there you can then upload the resulting JPG to another hosting site if you choose to or your own web server root folder then insert this HTML to the head of your webpage
  • Posted by on
  • Cycling Logo
    Which is best between Blogger and Wordpress to build a free website?
    I have not used Blogger but Wordpress is very intuitive and easy to use.
    Sep 22, 2014 | Computers & Internet
    How to add google apps to your website / domain powered by GoDaddy.com
    I am interested to add Google application to my website. Surely I will follow your way. Thanks for sharing. register website domain
    Jul 15, 2010 | Google Chrome
    how to create a website?
    You can create a website through blogger;
    www.blogspot.com
    hope this helps.
    Dec 18, 2010 | Computers & Internet
    1,127 people viewed this tip
    Top Cycling Experts
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you a Cycling Expert? Answer questions, earn points and help others
