By
IB4G2008
Rank: Wiz
Rating: 82%, 2402 votes
posted on Apr 25, 2008
Greetings,
This information is intended for those of you that are getting support from the Fixya.com expert community, for your printer. There are a few things you may wish to consider, prior to posting a request for assistance.
A. It's absolutely vital that you use the correct model number and maker's name for your request. Without that, no expert will be able to access their extensive information pool of techniques.
B. Speak just to the current issue. A reference to how long it's been working, is fine, yet presents little valuable information to an expert seeking to refine their response.
C. There are four major areas that represent nearly 99% of all printer issues. They are:
1. Ink issues. This usually happens when the cartridges are changed. It's vital to do a clean and calibrate, just after installing new cartridges. Try that first, and then a test page.
2. Paper jam issues. Visually inspect the inside of your printer, and focus on little slices of paper(comes from those papers with perforations).
3. Communications errors. Check all the cables for secure connection(they do come out sometimes, for no reason). Also, make sure that you have the most current drivers from the makers website.
4. Actual Print output issues. These are across the board, and without all the first 3 issues resolved, would simply add to your potential problem.
Most of the experts are good at what they do, and are willing to help you out. Help them, Helpya.
And, also, it's part of the experts program here to get constructive feedback from all helpees. Please consider adding your comments to the problems, so that we can all learn more about how to be better experts.
Thank you for your courtesy.
Patrick the Printer Man
IB4G2008 Fixya Wizard
Comment by IB4G2008, posted on Apr 26, 2008
Steve,
To get this handled, please repost it through the Ask an Experienced user for help window. Thanks..
We usually have comments to add value to the tips here, and the problems go on the main forum screen.
Thankya for using fixya
Comment by IB4G2008, posted on Apr 30, 2008
And also, en espanol, courtesy of BabelFish.com
y tambien, en espanol...
Saludos,
Esta información se piensa para las de usted que están
consiguiendo la ayuda de la comunidad experta de Fixya.com, para su
impresora. Hay algunas cosas que usted puede desear para considerar,
antes de fijar un pedido la ayuda.
A. Es absolutamente vital que usted utiliza el número de modelo
correcto y el nombre del fabricante para su petición. Sin ese, no hay
experto tener acceso a su piscina de información extensa de
técnicas.
B. Hable apenas a la edición actual. Una referencia a cuánto tiempo
se está trabajando, está muy bien, con todo presenta poca
información valiosa a un experto que intenta refinar su respuesta.
C. Hay cuatro áreas importantes que representan el casi 99% de todas
las ediciones de la impresora. Son: 1. Ediciones de la tinta. Esto
sucede generalmente cuando se cambian los cartuchos. Es vital hacer un
limpio y calibrarlo, enseguida después de instalar cartuchos nuevos.
Intente que primero, y entonces una página de la prueba. 2. Ediciones
del atasco de papel. Examine visualmente el interior de su impresora,
y céntrese en pequeñas rebanadas de paper(comes de esos papeles con
perforaciones). 3. Errores de las comunicaciones. Compruebe todos los
cables para saber si hay el connection(they seguro salen a veces, por
ninguna razón). También, cerciórese de que usted tenga los
conductores más actuales del Web site de los fabricantes. 4.
Ediciones reales de la salida de la impresión. éstos están a
través del tablero, y sin todas las primeras 3 ediciones resueltas,
agregarían simplemente a su problema potencial.
La mayoría de los expertos son buenos en lo que hacen, y están
dispuestos a ayudarle fuera de. Ayúdeles, Helpya.
Y, también, es parte del programa de los expertos aquí para
conseguir la regeneración constructiva de todos los helpees.
Considere por favor el agregar de sus comentarios a los problemas, de
modo que poder todos aprender más sobre cómo ser expertos mejores.
Gracias por su cortesía.
Patrick el mago del hombre IB4G2008 Fixya de la impresora
Comment #1
By
SteveGuno
Rank: Apprentice
Rating: 0%, 0 votes
HELP!!! A few days ago I was using my printer and it was doing okay, then all of a sudden it stopped printing. The printer kept running as though it was printing, but the pages came out clean with nothing on them. I have a "Lexmark , Z52 Color Inkjet" printer. I had refilled both ink cartridges recently, everything was working good, and then all of a sudden the printing just stopped. As I said earlier, the machine still runs just as though it's printing but the sheets come out clean. I've cleaned the cartridges, but to no avail. I've cleaned the inside as much as I can. I downloaded fresh drivers. I tried to uninstall the program, but I couldn't find the lexmark files anywhere, but the machine stills just as though it's printing. If someone could please help, it will be most appreciated. I couldn't get anything from Lexmark!!!
Thanks, Steve
