Tip & How-To about Samsung DVD-P241 DVD Player
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
Samsung DVD-P241 DVD Player Logo
I just purchased a 5300 home theatre system. When I insert a blue ray disc, it will play the previews, but when I hit the play putton, it goes to the settings menu. What seetting have I missed?
I would suggest to read on the owners manual first before operating your machine.and you can avail of the warranty if you found problem n your playaer...
Jun 13, 2011 | Samsung Televison & Video
how do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
Jul 26, 2010 | Samsung BD-P1600 Blu-ray Disc Player
I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Oct 17, 2009 | Samsung DVD-1080P9 DVD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
dvd-r problems
Unplug your AC power cord for a minimum of 30 seconds to clear the RAM. The RAM is used solely for dvd class history, and clearing this should solve your issue. If you want to convert your player to region free, which will allow you to play ANY dvd: 1 Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6 Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control A word of caution if your convert your player is that disc eject issues may arise in which you will have to eject from the unit, or toggle your power switch on/off.....good luck my friend.
May 16, 2007 | Samsung HT-DB120 System
2,002 people viewed this tip
Henry  Thomas
Henry Thomas
