Tip & How-To about Computers & Internet
How to burn iso image in Windows 7
Windows 7 finally introduces a feature that other operating systems have had for years - the ability to burn ISO images to CDs or DVDs. And it couldn't be much easier to use. Just double-click the ISO image, choose the drive with the blank disc, click Burn and watch as your disc is created.
Computers & Internet Logo
not booting ISO image
An ISO image needs to be burned to disk; you cannot boot from the image itself. A free program that can burn the image to a working file is called CDBurnerXP. It will burn CDs and DVDs.
Apr 21, 2014 | Lenovo ThinkCentre M93p 10AA - Tiny...
ya if i only could reload win7 and yes u will lose all info on hdd even the dummy password he put on to lock hdd amazing only thing it wont reload windows
Step 1:
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Step 2:
For Windows users who switch and upgrade from Windows Vista, one difference will be immediately noticeable when installing or upgrading to Windows 7, i.e. Install Windows 7 setup wizard no longer prompts or asks for user selection of which edition of the operating system to install. Instead, each Windows 7 DVD disc or Windows 7 ISO image will automatically install the preset specific edition which it's confined to.
Although Microsoft does not provide an universal "one disc rules them all" Windows 7 installation media, however the function is indeed supported. User just need to delete and remove the ei.cfg from any Windows 7 ISO disc image to convert the image into universal disc of any edition Windows 7 installer. For user who has the ISO image of Windows 7, and wish to make it an universal installer for any and all supported editions of Windows 7, as shown in illustration below, now has an easier way to modify the ISO. Instead of manually unpacking and extracting the content of ISO image (or copying files from DVD) to HDD, deleting the ei.cfg and then repacking or rebuilding installation files back into ISO to burn, user can now eliminate troublesome procedures by making use of "ei.cfg Removal Utility". clip_image001.jpg The ei.cfg Removal Utility is a simple tool that will disable the ei.cfg from any Windows 7 ISO disc image, thereby converting the image into a "universal disc" that will prompt the user to select a preferred edition during setup. ei.cfg Removal Utility works directly to patch the ISO image, by toggling the deletion bit in the UDF file table to instruct the operating system to ignore and remove ei.cfg, or treat it as if it does not exist. Best of all, ei.cfg Removal Utility can reverse the patching to restore the ISO disc image to its original state when the tool is been used to apply on a disc image that previously been patched by the utility. ei.cfg Removal Utility is a standalone portable app, and thus no installation required. In fact, the program does not have much user interface. After selecting the target Windows 7 ISO, the disc image will be patched right away. So make sure a copy of ISO backup is done. Download ei.cfg Removal Utility: eicfg_removal_utility.zip
Feb 14, 2013 | Computers & Internet
my acard technology pro burns dvds but the target dvds end up all scratchy like quality the pixels move and everything
is resolutions pixel problem only on the dvd disks you burn?
you might have to save the dvd to a file first then burn it to a dvd
are you copyning from another dvd or from a saved file ??
you might be burning it as data
this might be a problem with the quality of the dvd disks you are using or might be the software you are using there are lots of free burning sofrware programs on the internet
this might be because you have not selected the option to burn an audio or data dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/magicdisc/3000-7970_4-10383679.html
MagicDisc Virtual CD/DVD-ROM is a utility designed for creating and managing virtual CD drives and CD/DVD discs. MagicDisc Virtual CD/DVD-ROM emulates audio, data, and game CDs and DVDs with ISO image, CD and DVD images. MagicDisc Virtual CD/DVD-ROM offers 200x speed and noiseless CD/DVD access without a physical drive. It supports creating up to 15 virtual drivers. You can run games, software, see movies (VCD, SVCD, DVD), and hear music directly from your hard disk without inserting and swapping CDs and DVDs. MagicDisc allows you to use almost all CD/DVD image without burning them onto CD or DVD in order to easily access your favorite games, music, or software programs. It works like a real CD/DVD-ROM: You can run programs, play games, or listen to music from your virtual CD-ROM. It can compress ISO CUE MDS NRG CCD image; can encrypt ISO CUE MDS NRG CCD image; can make ISO image from CD/DVD; It can mount UDF only CD/DVD image and multi-session MDS/MDF and CCD/IMG image.
hope some of this helps you
Sep 10, 2011 | Acard Technology (ARS-2030LD) DVD±RW...
I cant burn my music onto CDs and my computer tells me i dont have a cd burning software when i should have one
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8
BurnAware Free is a full-fledged disc burning tool - fast, lightweight, feature-packed and, most importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray discs containing data, digital photos, music and video. With BurnAware Free, you will be able to create bootable or multi session CDs and DVDs, high-quality audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files, burn disc images, copy discs to backup ISO images and do a whole lot more.
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files; new option for setting the number of copies you want to burn (available for all disc formats); discs can now be verified immediately without being ejected first (if the drive supports this feature); numerous other small improvements that make the program easier to use and more effective; burn files and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC, WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD, Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc images; burn speed and other options can all be set automatically.
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
Macrium Reflect Free Edition. An award winning disk imaging solution for free. A complete disaster recovery solution for your home and office. Protect your personal documents, photos, music and e-mails. Upgrade your hard disk or try new operating systems in the safe knowledge that everything is securely saved in an easily recovered backup file. Macrium Reflect supports backup to local, network and USB drives as well as burning to all DVD formats. This version is for non-commercial home use.
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for performing a different task: Read - read a disc to an image file; Build - creates an image file from files on your computer or network (you also can write the files directly to a disc); Write - write an image file to a disc; Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare it against a given image file to ensure the actual data is correct); and Discovery - used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing.
Apr 19, 2011 | HP Computers & Internet
183 people viewed this tip
David Payne
David Payne
