Tip & How-To about Computers & Internet
How to delete oracle enterprise edition
Going through program files it's not deleted so firstly
start->run
type regedit.exeand then
select hkey_local_machine
next software in that delete oracle
then go back to program files then delete oracle
Computers & Internet Logo
how i can reuse the norton 360 v 4.3.0.5 Its trial period is expired. Plz send me product key or trial reseter. special thanks
Please remove the existing version of Norton program from the control panel, then go ahead and delete all Symantec and Norton files from the computer's C or D drive.
After that, open your registry and first take a back up just in case anything get deleted by mistake.
Then delete all Norton and Symantec files from HK CURRENT USER, HKEY LOCAL MACHINE, HKEY USERS, HKEY CURRENT CONFIG.
You can click on the SOFTWARE folder in each class to find the Norton files if any.
To open your registry editor, type regedit in RUN command (windows key+R)
After that you can again install a trial version of Norton for 30 days.
Feb 05, 2011 | Symantec Norton 360 Full Version for PC...
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
i have difficulty in uninstalling my nortan antivirus software
Here are the steps to Remove it Fully :
  1. Go to Start --> Control Panel --> Add/Remove Programs.
  2. Scroll down to your Norton program
  3. Click Change --> Remove All.
    You will be asked to restart your PC. Do so.
  4. Now go to Start --> My Computer --> Program Files. Right click on each Symantec folder and select Delete.
  5. While you are in Program Files go to the Common Files folder at or near the top of the Program Files window. Delete every Symantec folder there. And, again, restart your PC.
  6. Go to Start --> Search --> All Files and Folders --> More Advanced Options. Check each option except for "Case sensitive"
    Now type in Norton and delete each Norton folder from the search results (Again, right click, choose "Delete"). One more time, restart your PC.
  7. Repeat step 5 except type Symantec in the "Search" box.
The next step is trickier: go into the Registry.
  1. First thing to do is Back up the Registry. I'll be saying more about the Registry later. But suffice it to say that the presence of uninstalled security software in the Registry can conflict with newly installed security software and cause system freezes. So can folders of "uninstalled" programs for that matter.
  2. Once again, go to Start, then click on "Run". Type in "regedit"
  3. Go to the top of the Regedit window. Click (+) next to HKEY_CURRENT_USER. Go down the thread until you see Software. Click on Software and scroll down the thread until you see Symantec. Right click on Symantec and choose "Delete".
  4. From there go down to HKEY_LOCAL_MACHINE and repeat step 3. Restart your PC.
  5. Click (+) next to HKEY_LOCAL_MACHINE, now: Click (+) next to Software, Click (+) next to Microsoft, Click (+) next to Windows and Click (+) next to CurrentVersion.
  6. Select the Run folder. Right-click and delete each Symantec entry you see (if present). Restart your PC.
That should completely eradicate Norton Antivirus from your system!
Dec 09, 2008 | Computers & Internet
Spyware InstantShare removal
HI
go to start , run , type in regedit.exe
Registeration editor is displayed
go to HKEY LCM _MICROSOFT_WINDOWS/WINDOWSNT_UNINSTALL
Delete the uninstall entry. now go to search in the registery and delete all keys by typing the name and click search and delete.
Now delete all the program files that were installed with the programs
Nov 12, 2008 | Microsoft Windows XP Professional
epson v100 scanner
uninstall the program again, the software was not fully removed or go to
start
run
type regedit
go to hkey local machine
go to software
look for your software and delete that file
restart the computer
then install again your software
cheers
Sep 30, 2008 | Epson Office Equipment & Supplies
125 people viewed this tip
David Payne
David Payne
