Tip & How-To about Philips Magnavox 27MS343S 27" TV
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
Philips Magnavox 27MS343S 27" TV Logo
i have an m# ts3270 b101 stuck in the demo mode. would luv answer to problem, i am draining my family of their patience.
Man o man, just moved my same model Magnavox and have the same problem. Staying in demo mode...
Dec 18, 2010 | Philips Magnavox 27MS343S 27" TV
i have a 1996 magnavox tv that is in demo mode and you can only turn the tv off by unplugging the tv
Those older Magnavox sets had a demo mode available from the on screen menu. Go to the menu and disable the demo mode, that will fix the trouble. When in the demo mode you will have no control over your set by remote or front panel controls. You can still address the menu though to turn off the demo mode.
Apr 17, 2010 | Televison & Video
DEMO MODE
Hello hoz685,
push volume up
and volume down buttons at the same time
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 01, 2009 | Philips Magnavox 51MP392H Rear Projection...
closed caption
The set is in demo mode press the volume upand the volume down button at the same time on the set.
Aug 11, 2008 | Philips Magnavox 27MS343S 27" TV
magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
1,971 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
