Tip & How-To about Computers & Internet
For knowing your PC better and easier operation
Most people don't know how to maintain a PC for safe and proper operation so thats why they have so many hardware and software problems so here is what I recommend most average users do, find a class in your local area that teaches you how to protect your PC and how to maintain your system that you are running and what programs are safe and ones that are the best to use right now and what is the best configuration for you PC so you have a smoother PC experience if you live in Burnsville, Savage, Prior Lake, Egan, shakopee mn. then email me at cs0039tv@hushmail.com for an appt. for a cheap class ask for T
Computers & Internet Logo
dell inspiron mini 10 Turn it on, put in password. screen says windows did not start up sucessfully. A recent hardware or software change may have caused this. then i go to the last known good configuration- start windows normally. theres also option for- safe mode- safe mode with networking- safe mode with comand prompt. all of these options take u to a page that says; a problem has been detected and windows has been shut down to prevent damage to computer- unmountable_boot_volume. then at the bottom it says; technical infromation: ***STOP: 0xooooooed (ox86fc67b8, 0xc0000006, 0x00000000, 0x00000000) cant get it off this screen to try to do anything. tryed all buttons, ctrl+alt+delete...... help plz
A blue screen with white writing appears on my computer,
just before windows is about to begin and it reads:
A problem has been detected and windows has been shut
down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've seen this stop error
screen restart you're computer.
If this screen appears again follow these steps:
Check to make sure any new hardware or software is
properly installed. If this is a new installation, ask
your hardware/software manufacturer for any windows
updates you might need.
If problems continue, disable or remove any newly
installed hardware/software. Disable BIOS memory options
such as caching or shadowing. If you need to use safe
mode to remove or disable components, restart your
computer, press F8 to select advanced startup options,
and then select safe mode.
Technical information:
STOP: 0XOOOOOOED
(OX8OED4AF8, OXCOOOOO32, OXOOOOOOOO,OXOOOOOOOO)
I cannot go into windows even in safe mode, and I don't
know how to execute any of the other things it's telling
me to do.
It may have something to do with my virtual memory as
windows had to increase it while I was playing a computer
game, or because I added some extra pictures I downloaded
to a computer game folder where the default pictures were
already stored.
if u cant do these then reinstall the operating system.
Sep 03, 2011 | Dell Inspiron Mini 10 Notebook
Always got blue screen that saying got problem with the graphic, either the software or the hardware. After several time trying and logging in, the screen terribly lagging.
Does it run properly in Safe Mode? (Press F8 when starting computer and choose safe mode)
What operating system are you running? Have you tried to do a system restore?
Jan 15, 2011 | Computers & Internet
windows does not shutdown properly, asks me if i want to restart in safe mode?
It never hurts to start in safe mode. While in safe mode, some things will not be available to you. Be aware that there is a reason your computer is telling you to start in safe mode. Something happened, hardware or software related, that caused a problem. Windows allows you to start in safe mode to correct problems. Not knowing what the problem was, I might suggest starting in safe mode, then go to start, all programs, accessories, system tools, then system restore. Try to restore your computer to a few days ago when it was working properly. Then restart, and hopefully it will work.
Aug 22, 2010 | Acer Aspire One PC Notebook
what is safe mode?
safe mode is the mode which is used fix some problems like software or hardware conflict problems ...
safe mode loads with the minimum system files & drivers by using which you can solve the hardware conflicts & software conflicts problem easily ....
to go to safe mode you must press F8 before the operating system loads i mean in the starting of the system only..
Apr 15, 2008 | Compaq Presario 5000 PC Desktop
dileep...
Apr 15, 2008 | Computers & Internet
118 people viewed this tip
David Payne
David Payne
