Tip & How-To about Washing Machines
Problem Accessing a Specific Website ?
Problem accessing a specific site ? Try these solutions.
Clear your browser cache
Try clearing your browser cache. If you are unsure about how to do this; please follow this link : Click here
Sometimes this won’t work and you may need to try something else, if clearing your browser cache is not working for you then now it’s time to do a little trick. We need to flush(clear) our local DNS cache (This is very useful while you are busy moving your site; mostly because your local dns cache usually remembers the previous results for a few more minutes.) Let us see how to clear the local dns cache.
Clearing Local DNS cache (Windows)
If you are using windows then you have to open your command window (go tostart menu -> click on run -> type cmd there and press enter.), make sure you have administrative privilege to do this. Now you have to type a command inorder to clear your DNS cache.
ipconfig /flushdns
this will help you clear the local dns cache (If you are on windows vista you have to start your command prompt with administrative privilege; which can be done by typing cmd in the search field in start menuand then right click and you will see a Run as administrator option and execute the above command)
Clearing Local DNS cache (Linux)
I am using Ubuntu; by default it doesn’t come with the daemon to flush the local DNS cache; so if you are using Ubuntu linux then you will have to install nscddaemon by running the following command in your terminal.
sudo apt-get install nscd
Once nscd daemon is installed you can run by typing the following command
sudo /etc/init.d/nscd restart
If you are using other Linux flavors probably you can try this and see if it works.
try this command in your terminal : /etc/rc.d/init.d/nscd restart
Still your problem is not solved ?
Then most probably it has something to do with your Internet Service Providers DNS cache; So call then and tell your problem, they will provide you with an alternative proxy address, or they will solve the problem for you.
If you are a Virgin Meda Broadband user in UK, then try this
I use the Virgin Media Broadband; they have provided me with a new proxy address : webcache.virginmedia.com and port: 8080
(Follow the instructions here to set up your proxy settings)
Best Regards
NextDoorNerd
Washing Machines Logo
chatango cannot connet
Help: trouble shooting If nothing else has fixed your problem, you could try these general solutions.
Clear your cache Clear your browser's cache (the temporary files your browser stores to make sites load faster). Sometimes an old or incompatible file may be stored in your browser's cache. If you clear the cache new files will be downloaded the next time you visit the page.
Update your Flash Player Chatango runs using the Adobe Flash Player. You can download the latest version here.
Update your browser - or try a different browser Sometimes an old browser may not work well with new sites. Try getting a modern browser:
Chrome
Firefox
Internet Explorer
Check your internet connection Chatango will not work on proxy connections.
Try a different way of connecting to the internet and see if that solves your problems.
If it works on your computer or device with one connection but not another - the problem is probably with the connection.
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
May 09, 2014 | Microsoft P73-05363 Windows Server...
how do I stay signed in
May 07, 2014 | Microsoft Computers & Internet
Why is my Facebook account unavailable because of site maintenance. try again in several hours!
Try and e-mail the support service and ask them what is wromg with your account i think the will give you a right answer over that
Oct 23, 2009 | Facebook Social Network
Browser doesnt load page
Just like a computer browser, whenever you browse the internet, the G1 will download images, text, passwords, etc from all sites accessed. it places this info in a place called a 'Cache'....it can get so full it will prevent pages from loading. to fix this, clear your cache. there are 2 ways to do this.....
1: MENU > SETTINGS > APPLICATIONS > MANAGE APPLICATIONS > BROWSER > CLEAR DATA
2: BROWSER > MENU > MORE > SETTINGS > SELECT CLEAR CACHE, CLEAR HISTORY, CLEAR ALL COOKIE DATA, CLEAR PASSWORDS
after doing that, turn off and on the handheld and try it again. if you keep up on doing this everytime youre done browsing the web, it wont happen again.
good luck :)
Nov 03, 2008 | HTC G1
setup problems
you need to clear the browser's cache
you did not specify your browser so i will assume this tips will involve your browser.
to do that
How do I clear cache using Netscape? Question : Answer : help_a.gif Cache files, or Temporary Internet Files in Microsoft Windows 95 or higher, are copies of files sent to your web browser and stored on your computer so that when you access a web site (such as PayPal) at a later date, it will load much faster. However, sometimes cache and temporary Internet files can cause problems in viewing your current information on the PayPal web site.
To set the size of the memory cache or clear it in Windows or Unix, follow these steps:
  1. From the Edit menu, click Preferences.
  2. Open the Advanced category on the left hand side of the screen and click on Cache. You should see an option to clear your disk and memory cache. It is recommended you clear both caches.
  3. Click Clear Memory Cache.
You may also need to locate the folder on your hard drive named Cookies or Magic Cookies and delete all the cookies that are stored there.
How do I clear the cache using AOL with a Mac? Question : Answer : help_a.gif Cache files, or Temporary Internet Files in Microsoft Windows 95 of higher, are files sent to your web browser and stored on your computer so that when you access a web site (such as PayPal) at a later date, it will load much faster. However, sometimes cache and temporary Internet files can cause problems in viewing your current information on the PayPal web site.
If you experience difficulty viewing a web page, your computer's cache file may be corrupted. Additionally, if you do not manually (or automatically) set your cache files to be deleted periodically, you may experience delays in loading and closing out of certain web pages.
To improve your computer's performance accessing the web, and specifically while visiting PayPal, regularly clear your cache file.
To clear the cache with AOL on a Apple Macintosh, follow these steps:
info_sm.gif Here's How: pixel.gif
  1. Click My AOL at the top of your browser.
  2. Select Preferences.
  3. Click the WWW icon on the left hand side.
  4. On the right hand side, click Empty Cache Now.
Oct 18, 2008 | PayPal Computers & Internet
388 people viewed this tip
Top Washing Machines Experts
