Tip & How-To about Computers & Internet
5 Routines to Speed up Your PC
1. Avoid Crowded Desktop
Do you have thousands and thousands of tiny little icons filling up your desktop? Each time our operating system loads it uses the memory to load all the files in the desk top; every time you refresh your computer it also steals your time to reload all the files in the desktop. So my word of advice is ‘KEEP YOUR DESKTOP CLEAN’. Keep only the important shortcuts in the desktop, keep your files in other folders say for example My Documents or in other Drives, etc.
2. Viruses, Malwares and Spywares
Every computer is prone to malwares; when it comes to windows machines they are more vulnerable. Regularly check your computer with a good antivirus software and an anti spyware software (Avast and Ad-Aware are two good free software for this purpose). Also using a firewall will help you prevent some attacks. Performing Regular Virus and Malware checks can help your computer stay healthier and thus improve performance.
3. Unused Programs
Most of us install programs for short period usages. If you have any program that you are no longer using, remove the unwanted programs (Revo Uninstaller is good software that can help you remove unwanted programs effectively). This can help you increase your computer’s performance.
4. Remove Programs from Startup
Have you ever noticed tons of tiny little icons in the right end of your task bar? They can cause your machine slow down dramatically because many of those programs start with your operating system and thus use the valuable resources we need to perform our activities.
You can remove them: Go to Start Menu -> Run and type msconfig and go to the startup tab. Remove all the programs you don’t want to start with your windows by de selecting them.
5. Optimise your hard disk performance
With time the hard disks get filled with fragmented files, corrupted files and temporary files, etc. This can cause your system to perform really slowly. If you don’t regularly check your hard drive for errors and defrag it then it can be deadly.
Instructions to defrag your hard disks : Click Here
Instructions on checking your hard drive for errors Click Here
Visit this page for removing temporary and unwanted files: Click Here
If you can follow these five suggestions regularly then you will have a stable performance from your pc. Stay tuned for other tips.
Best Regards
NextDoorNerd
Computers & Internet Logo
how to change wallpaper on msi netbook
Which operating system ?
You can change your Windows 7 Desktop photo, also called wallpaper quickly and easily. If you like variety, you can alternate photos and settings on your computer display as well. It takes very little effort, time and computer knowledge to do change your Microsoft Windows Desktop appearance.
Bring up your Microsoft Windows 7 Desktop. Let all the software load completely. You will know it is done when all icons appear in your Windows task bar in the lower left hand corner. Right click (opposite of left click) once on a blank space on your Desktop where there are no icons. This will display a properties menu. Choose personalize from the menu that appears. Notice the different categories of wallpaper that appear. Choose the one you like best. Wallpapers are displayed as tiny icons but you can double-click to see a full image. Click a folder, such as pictures if you would like a picture or wallpaper from your own collection or the Internet. Windows 7 will save this background in your collection for future reference. Check the box that says change picture and choose amount of time you would like the wallpaper in Windows 7 to be displayed. This step is optional. Select picture position. Here you may have to experiment until you find one that fits your screen (resolution) the best. Choose what looks best for you, do not get caught up in the numbers or labels. Hope this helps.
Jan 14, 2013 | MSI U130416US Netbook
I have a laptop that will load up but with no desktop icons
that means that the original file or the path of the shortcut does not exist. note down the type of shortcuts you are facing problems with. if it is regarding My computer, My documents, etc. delete the shortcut files. right click on the desktop then go to properties.Click on Desktop tab then click on customize desktop button at the bottom left. under desktop icons, click on all the boxes to activate the icons to appear on your desktop.
cheerz.
Feb 21, 2010 | Microsoft Windows XP Home Edition
How do I adjust my monitor? My home page does not
I'm not sure what operating system you're using nor what you mean by your "home page". If you mean your browser window doesn't fill the whole Windows desktop, what happens when you maximize the window?
If your desktop looks huge with tiny icons (and tiny-looking windows, if you have any open and not maximized) all clustered in the middle of the screen, your display resolution may be set higher than you're accustomed to. In most versions of Windows you can go to Control Panel | Display, see what your current resolution is, and try adjusting it. The higher the numbers, the "bigger" the desktop area (and the smaller the icons and everything else). If you adjust the resolution higher than your monitor can handle, you may lose your display and have to restart the computer in something like Safe mode to get to Control Panel and readjust it. If you adjust the resolution lower (or run in Safe Mode) your icons may not fit on the smaller desktop and may get scrambled. In that case, first straighten out the display resolution, then move your icons back where you want them.
Jun 14, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Windows xp dekstop icons not displaying
1. Right-click the desktop, and then click Properties.
2. On the Desktop tab, click Customize Desktop.
3. Under Desktop icons, click to select the check boxes of the icons you want to view.
4. Click OK two times.
Dec 03, 2008 | Compaq Presario Notebook
179 people viewed this tip
David Payne
David Payne
