Tip & How-To about Computers & Internet
Belkin Basic, Surf , Share, Play and Playmax, Routers
For all these products
Update the Firmware immediately after the installation is complete
this will reduce most of the issues in connectivity
Computers & Internet Logo
epson stylus workforce firmware problem
You have attempted to update your Epson product using the Epson Driver Update and Download Navigator software but have found that the product is stuck in Recovery Mode. This message is displayed on the product's LCD screen and you will be unable to perform any actions until this issue is resolved.
This error can occur if the firmware update procedure is interrupted, e.g. accidental powering off the product, cables being removed or the installation being cancelled.
SOLUTION:
The first method of resolving this problem is to wait for a few moments and a pop-up should appear on the computer screen, clicking on the link indicated below will direct you to a tool that will correct this issue.
In the event that the pop-up mentioned above does not automatically appear or has been accidentally cancelled, the Firmware Recovery Tool can be accessed manually. Follow the instructions below:
  1. Go to the Epson Support website and select your product using the drop-down lists presented.
  2. Click Drivers & Software.
  3. Firmware Recovery Tool will be listed, click direct download.
  4. Read the license agreement and tick the I have read and accept these license terms box and click proceed to download if you would like to continue.
  5. Once the download is complete, run the file as normal for your operating system and follow the on-screen instructions to complete the firmware update.
May 12, 2013 | Office Equipment & Supplies
hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
6110 officejet, power light blinks. display says "warming up" continuously?
Pls run the attached file to resolve the issue.
Description:
These all-in-one product firmware updates will resolve issues with receiving faxes, warming-up, certain printing issues and memory full messages with the HP OfficeJet 6100 series products.
Warming-up - Under certain circumstances when the all-in-one will display "warming up" indefinitely after pressing one of the "Copy" or "Scan" buttons
After downloading and installing this firmware update, the software will determine if the hp all-in-one would benefit from this firmware update and inform you of the results.
Installation Instructions :
Download the file "HpAiOFWUpdate2_2.exe" via http://www.printer-drivers.com/drivers/246/246484.htm to a local hard drive. Make note where (in which folder) the file gets copied.
The hp all-in-one software for the OfficeJet 6100 series must be installed on your PC before installing this firmware update. The OfficeJet 6100 series must also be connected to your PC and turned on before proceeding.
Locate the file "HpAiOFWUpdate2_2.exe" on your hard drive and double-click the file to install the firmware update.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 15, 2009 | HP Office Equipment & Supplies
mine does the same thing too
Go to the RCA website.
http://www.rcaaudiovideo.com/product.aspx?product=408
download the firmware.
After you download the firmware
plug your mp3 player into usb device of your computer
Then install the firmware.
And you pc will reconize it.
Oct 21, 2008 | RCA OPAL M4001 MP3 Player
258 people viewed this tip
David Payne
David Payne
