Tip & How-To about Cell Phones
HOW TO FIX YOUR TOUCH SCREEN PHONE
WHAT YOU CAN DO IF ITS NOT WORKING IS YOU CAN TURN YOUR PHONE OFF, TAKE THE BATTERY OUT , RUB IT AND PUT IT BACK IN THEN IT SHOULD BE GOOD AS NEW.
Cell Phones Logo
what can I do if i left my cell phone under the sun and its get wet
take the battery out immediately and put phone and battery for an hour or so then clean with a qtip and a little rub alchohol on qtip then put back together and try to turn on good luck
Apr 26, 2011 | Samsung Star GT-S5233 Cell Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
"use genuine battery"
Sadly it does happen to these phones more often then it should...
The best you can do is either get a new battery from your local dealer(or online) or just clean the contacts really good with a q-tip and rubbing alcohol.
If the phone receives a charge that isn't the rated from it's normal battery it freaks out and says that you're using a poor battery... It's really stupid.
Jul 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
I left my phone in the yard and it got rained on (don't ask), and I brought it inside, took the battery out, and let it dry for a day. I reinserted the battery and it worked for a few days until i got the "Use genuine battery" message. I put a small piece of white paper (actually the back of the label of a bottle of Blue Moon) over the moisture indicator, put the battery back in, and everything worked, much to my surprise.
Sep 21, 2007 | LG VX8300 Cellular Phone
how do i resolve the error: use genuine battery. power off
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
Nov 08, 2006 | LG U8150
133 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
