Tip & How-To about Computers & Internet
Set up a computer-to-computer (ad hoc) network
An ad hoc network is a temporary connection between computers and devices used for a specific purpose, such as sharing documents during a meeting or playing multiple-player computer games. You can also temporarily share an Internet connection with other people on your ad hoc network, so those people don’t have to set up their own Internet connections. Ad hoc networks can only be wireless, so you must have a wireless network adapter installed in your computer to set up or join an ad hoc network.
Click to open Connect to a Network.
Click Set up a connection or network.
Click Set up an ad hoc (computer-to-computer) network, click Next, and then follow the steps in the wizard.
Notes
If one or more of the networked computers is joined to a domain, you need to have a user account on that computer to see and access shared items on it.
If the networked computers are not joined to a domain, but you want to require people to have a user account on your computer for access to shared items, turn on password protected sharing in Network and Sharing Center.
To turn on password protected sharing
Click to open Network and Sharing Center.
Under Sharing and Discovery, if password protected sharing is off, click the arrow button to expand the section, click Turn on password protected sharing, and then click Apply. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
An ad hoc network is automatically deleted after all users disconnect from the network or when the person who set up the network disconnects and goes out of range of the other users of the network, unless you choose to make it a permanent network when you create it.
If you share your Internet connection, Internet connection sharing (ICS) will be disabled if you disconnect from the ad hoc network, you create a new ad hoc network without disconnecting from the old ad hoc network for which you enabled ICS, or you log off and then log back on (without disconnecting from the ad hoc network).
If you set up an ad hoc network and share your Internet connection, and then someone logs on to the same computer by using Fast User Switching, the Internet connection will still be shared, even if you didn't intend to share it with that person.
I hope you all found this information useful and helpful.
Phillip
Computers & Internet Logo
why does connecting to an ad-hoc network disconnect the shared mobile broadband connection?
You can be connected to two signals at one time, if I understand your statement. My question is, why is your laptop automatically connecting to a Ad-Hoc network? Your wireless adapter Intel Wireless 3945A/B/G,settings should be scrutinized. Perhaps this will help:http://www.intel.com/p/en_US/support/highlights/wireless/pro3945abg
Dec 15, 2012 | IBM Lenovo ThinkPad Z61m 9452-J4U PC...
how do i transfer files using win 7 ad hoc?
setting up a ad hoc connection is the most simple solution to to transferring files from one computer to another directly.
to set up ad hoc in windows 7
Open network and sharing centre from your control panel. Click Set up a new connection or network and choose set up a new ad hoc connection. Follow the instuctions in the wizard to set up the network sucessfully. Use the other computer to connect to the network and share files at your will...
Mar 27, 2011 | HP Compaq Presario CQ50-110US Laptop
i can't get the internet sharing to work. i had installed and configure the wireless router, Linksys WRTG45 connected to a desktop pc running win7. internet sharing is enabled on the modem. now we're using ad hoc connection to share this internet connection.
If you are using the wireless router then you will not use the Ad-hoc mode.
You aloso don't need to share the internet on the modem.
make sure that if you conecnt the computer directly to the modem, it goes on line.
If it is on line then you can connect the modem to the router and computer to the router.
open the setup page and change the settings of the router.
once ytou setup the router then you should be able to go on line on all the computer.
You just need to connect to the network on other computers.
Click Here for more information about the routers and network
Aug 18, 2010 | Computers & Internet
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox 360 Console
518 people viewed this tip
David Payne
David Payne
