Tip & How-To about Office Equipment & Supplies
What to do when you lose your ID and have a print job running.
You send a print job to the printer and it asks for your user ID which you forgot or threw in the trash. Now the printer will not print, the job cannot be deleted and the computer will not cancel the job.
If the print job is not that important shut the printer down and remove the power cord for about 30 minutes. When you turn it back on the unit will reset and erase any print jobs. This is your easiest solution but only if you do not have to be concerned about the print job.
As far as the computer, you can reboot it also which will erase any print jobs.The unit may not reboot because it cannot shut down the print job. In this case it may require using control + alt+ delete (all at the same time) if any of the programs say that they cannot shut down. You will get the Windows Task Manager and will have to make a selection on the software you want to stop from running. Obviously it will be the print driver.
If you threw the ID into the trash and have not emptied the trash yet, open the trash icon and see if the user name is still there. This may save you some problems and you can retrieve it by moving it back to the original location by clicking on restore all items. This may restore more than you want but any unwanted files can be put back in the trashl
Thanks for using FixYa and for the great rating.
hardrocko
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    forgot user ID and password
    It depends on the website that you are login on to. most of the time is you forgot your user id and password it will send the info your email so just click on forgot used id or forgot password. Again click on either one and it will ask for your email and then send you a link to recover or reset. Good Luck.
    Jun 28, 2015 | Computers & Internet
    forgot my password and dont have friends to call
    Go to their site and look for "forgot password", they will ask for user ID and send you the password to the user ID account.
    Jan 29, 2015 | Facebook Social Network
    I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print and I get an "access restricted" message in the job history log. User ID shows has a question mark in it. The log shows the job name and the user who sent but with 0 pages printed. I've tried different drivers and setup. I currently have it set up for LPR printing with a queue name of PORT1. I've tried lp, ip address, and PASSTHRU. They all seem to give the same results. This has to be simple
    Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
    Apr 17, 2010 | Ricoh Aficio 1232C Color Copier
    Konica 7155 Main Error Code : 74 ,printer stops for no reason
    There are a few code 74's, and Konica has a bulletins on them.
    DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
    SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
    DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
    SOLUTION: CAUSE: Booklet tray is full.
    SOLUTION: Remove the paper from bottom exit of the finisher.
    DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
    SOLUTION: CAUSE: Paper remains inside finisher.
    SOLUTION: Please remove copies from the finisher.
    DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
    SOLUTION: CAUSE: Punch trash box is full.
    SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
    DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
    SOLUTION: CAUSE: Sub-tray (first tray) is full.
    SOLUTION: Sub tray is full. Please remove paper.
    I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
    Apr 23, 2008 | Office Equipment & Supplies
    188 people viewed this tip
    k24674
    jasbo
    jasbo
