Tip & How-To about Televison & Video
If your picture is fuzzy you need to change the fluid in CRT's. Over time the fluid gets old and cloudy and light cant shine through properly makeing your picture fuzzy
Televison & Video Logo
how do i fix fuzzy picture
It could be the crt cooling fluid in the tubes. Over time they can become cloudy and discolored, making your picture appear different looking than originally.
Mar 23, 2011 | LG RU-44SZ51D 44" Rear Projection...
fuzzy picture on tv 54in
Check your coaxial cable connection and inspect it wiggle it while the set is on if the problem clears replace the cable. Check to see if the male connector that sticks out the back of the set isint loose to the point where it moves when you touch it. If it does you need to have it looked at by a tech usually this problem can be solved with a little soldering but could get more complicated. Depending on the age of the set the fluid in the CRT's gets old and cloudy and light cant shine through it makeing your picture appear fuzzy. Your local tech should be able to change the oil in your set. Finally you could have some bad filter caps but I doubt it.
Jun 12, 2010 | Akai PTH5498 54" Rear Projection...
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
no blue manual convergence - Samsung pcj522r
Thats a very strong possibilty the phosphorus may be burned off the CRT face. Does the blue project when powerd up and looking in from the raer of the set? Look into the blue CRT lens while its playing If you can see a clear picture I would think that you have some open resistors in the blue circuit, If you cant see a picture its time for a CRT. If you need a CRT let me Know I have a good source for them Used.
Jun 21, 2008 | Televison & Video
Mitsubishi 65809 65 in Blue color and center screen fuzziness
Projection TV's use a cooling fluid around each of the 3 CRT's that the light has to shine through. Over time, it will grow a bacteria in the fluid (just like sunshine on the ocean) and turn cloudy. The blue CRT is most subject to this. You need to have the fluid replaced, which can be a messy job better done by a pro, but many have done it themselves. If you are interested, I'll go into the details.
Might want to replace the convergence amps while your at it.
Hope Ya Fix It!
Feb 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
407 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
