Tip & How-To about Washing Machines
F11 solution
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Washing Machines Logo
ive got f11 flashing on my machine could u explain my problem
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check MCU
  • Check CCU
  • Check Motor
Hope this sheds some light on your problem!
Mar 30, 2010 | Whirlpool Washing Machines
the F11 code keeps coming on
Hello there :\
The dreaded
F/11 Serial Communication Error
  • Check MCU
  • Check CCU
  • Check Motor
Dec 31, 2009 | Kenmore Elite 45986 Front Load Washer
whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
washer has an F11 code what does that mean?
F11 means Serial communication error
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check MCU
• Check CCU
• Check Motor
(Refer manual to test the components)
Replace failed component.
Preferred to be done by a technician unless you are handy.Good luck with the machine.Hope I answered your question.
Apr 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
May 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
184 people viewed this tip
Top Washing Machines Experts
