Tip & How-To about Computers & Internet
Where to find the I.P address (Windows Vista home premium)
If you need to find your I.P. address (Internet Protocol), simply click on the small computer screens at the bottom right of your taskbar, After you do that you will see information about your current internet connection and two options to either connect or disconnect from a network or to open the network and sharing center, click on the network and sharing center option.
After clicking on this option a new window will open with multiple options about your current network and sharing settings. About 3/8 the way down in the window will be information about your current network, you are going to want to click on view status. After you click this a new smaller window will open.
Once this window opens you are going to click on details, this will open another window. This is the last window and it will display all of the technical information about your current network. The I.P. address should be the fifth item in the list, it should look something like "IPv4 IP Address 123.456.7.8.
Computers & Internet Logo
how do I pin my email address on taskbar and desktop
You can pin your email account to the taskbar or screen. Windows 10 = right click on screen, new shortcut, then type in the shortcut. then click next, then for the name you can type in your email address.
Sep 26, 2017 | Computers & Internet
i cannot connect to the WFC because it needs the ip adress and the connection fails
Click start type cmd press enter you will be in DOS mode
type in ipconfigpress enter you will see all of your internet connection details type in your default gateway ip adress into your internet search should read something like 10.0.0.138
Your IP Address should be thought more as your computer's phone number than it's address, if you have multiple connections, you have multiple IPs if you dont have a connection, you dont have an IP.
Without further delay If you need your computers IP address:
This will work in almost every case, it simply requests the website's server to tell you what your IP is. http://whatismyipaddress.com/
I have included a link to make things easier.
If you are in a network and need your computers local address.
Hold the windows button (looks like the windows banner, usually between left ctrl and left alt) and press 'R'.
A box will display, and type in "cmd.exe" and hit enter.
The 'command prompt' will display, a black screen with white lettering.
Simply type in ipconfig. This gives information on all your internet connections.
Look for the line "IPv4 Address".
If you need to find the IP of a current connection you can type (from the command prompt) "netstat".
This will give you all your current connections.
To identify a specific one, the easiest way is to run it before you establish the connection then again afterwards.
Change IP Addresses
Your IP address is a series of numbers that identify your specific computer on the Internet.
If, for some reason, you want to change your IP address, you can do so without going into the command prompt.Click "Start," "Control Panel," "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings."
Right-click the network you want to change and click "Properties."
Click the "Networking" tab.
Put a check either next to Internet Protocol Version 6 (TCP/IPv6) or Internet Protocol Version 4 (TCP/IPv4) and click "Properties."
Click the radio button next to Obtain an IP Address Automatically if you want Windows to assign one, or click "Use the following IP address" to manually change it.
Enter the requested information and click "OK."
Mar 01, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
ip address
Find my IP Address
type in ipconfig press enter you will see all of your internet connection details type in your default gateway ip adress into your internet search should read something like 10.0.0.138
How to Change IP Addresses
Aug 16, 2013 | HP Photosmart C6180 All-In-One InkJet...
need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
158 people viewed this tip
David Payne
David Payne
